spark plug change - 1999 Eldorado
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By 98cadillac
  • 1 Post By Ranger
Cadillac Seville / Cadillac Eldorado Forum Discussion, spark plug change - 1999 Eldorado in Past Cadillac Vehicle Discussion; Hello to all! I bought my first Cadillac Eldorado a 1999, 90,000 miles. I am trying to change the spark ...
    rbcoats is offline Cadillac Owners Member
    Automobile(s): 2008 cts
    Jun 2013
    63
    9
    Hello to all! I bought my first Cadillac Eldorado a 1999, 90,000 miles. I am trying to change the spark plugs and have got the 5 easiest ones done. My question is how do I change the last 3 plugs that are on the back of the engine under Neath the coil pack?
    EDIT by Moderator: Proper vehicle model year.
    68
    82,076
    Re: spark plug change
    With great difficulty and several bandages. It's been a while. That's all I remember.
    98Geldog is offline Cadillac Owners Fanatic
    Automobile(s): 1998 eldorado, 2000 Catera
    Dec 2010
    Chicago
    247
    I bought a long spark plug socket with extension attach to it from autozone or orileys that makes changing the plugs a 15 minute job
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by rbcoats View Post
    Hello to all! I bought my first Cadillac Eldorado a 1990, 90,000 miles. I am trying to change the spark plugs and have got the 5 easiest ones done. My question is how do I change the last 3 plugs that are on the back of the engine under Neath the coil pack?
    Doesn't this car have a distributor?
    If 1990 was a typo and it is a Northstar, unbolt & lift the coilpack.
    68
    82,076
    ^^^^ Good point. I missed that and assumed it to be a 4.9.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Disconnect the torque struts, and put a turnbuckle in ones place to pull the engine forward slightly.
    Not much sense spending R&D money making it slightly easier to access something that only needs to be serviced every ~50K (copper plugs)-100K miles (platinum plugs).
    Now try doing plugs on a V10 van .
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    The rear spark plugs on the Northstar aren't that hard to get to. Not quite as easy as the front, but not too bad.
    vincentm likes this.
    Jun 2013
    63
    9
    sorry for the mistake, the year is 1999.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,259
    rb, While you are doing the right (rear) bank of spark plugs, also remove the coils and ICM for a good contact/connector cleaning. Also check the integrity of the ICM ground wire.
    There are two pre-2000 spark plug wiring diagrams (it's important) in my albums. The Community tab ^^^, Albums, the red Seville - 2 albums, 6 pages.
    68
    82,076
    Re: spark plug change - 1999 Eldorado
    Ahh, so it was a typo. In that case, it's easy. I never used a turnbuckle. Just removed the strut tower brace (if so equipped) as well as the ICM (with coils and wires still attached). Be advised that there is a hidden mounting bolt on the back side of the ICM that requires the Braille method to remove and install. After that it's fairly easy access. MUCH easier than the 4.9.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Rear plugs are easy, only frustrating part is not having a plug socket that isn't magnetic, and the plugs drop back in after loosening them.. >.<
    Feb 2013
    306
    The plugs are held by the rubber part of the spark plug socket I use so thankfully they don't drop back in for me.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Yea, my dad taught me to loosen the plug then use the boot of the wire to pull it out. old mechanics trick
  16. #14
    68
    82,076
    A 6-12" length of heater hose works very well to remove and reinstall them.
  17. Remove Advertisements
