Unknown branch on wiring harness
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, Unknown branch on wiring harness in Past Cadillac Vehicle Discussion; I am in the final stages of preparing to reinstall the engine after installing studs for the heads and have ...
    hfg1551 is offline Cadillac Owners Member
    Automobile(s): 1998 Seville STS
    Sep 2010
    53
    I am in the final stages of preparing to reinstall the engine after installing studs for the heads and have found a branch of the wiring harness that has no plug and 4 exposed wires. I am sure that this didn't happen during removal and disassembly and there are no corresponding plugs with exposed wires attached to anything near the harness.
    From the attached pictures does anyone have an idea where it goes and to what it should be attached?
    Wingralf is offline Cadillac Owners Member
    Automobile(s): 1996 Seville STS
    Oct 2003
    Indianapolis
    49
    35
    Re: Unknown branch on wiring harness
    It plugs into the switch at base of shifter, its at top on tranny middle rear area real pita to get too.... (neutral safety/gear selector switch) I hate that connector I had a pin burnt in it
    jim
    Oh and double check ground wires, if same as 96, 1 ground at/near rear head that a engine/tranny mount bolts too is for o2 sensors... and my personnel most hated but easy to get to ground right side lower block under same head near the speed sensor on tranny. its the PCM ground. car will start drive a few miles LOL and die and not restart run a self on board test it comes up as NO PCM that a dead give away if its off or broken..... yup hate that one..
    Jim
