brake sensors
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, brake sensors in Past Cadillac Vehicle Discussion; Hi everyone , I have a 2001 caddy Seville SLS , VIN-Y 4.6 , anyway , I have intermittent "change ...
    timman is offline Cadillac Owners Fanatic
    Automobile(s): 1996 cadillac deville
    Jun 2010
    105
    brake sensors
    Hi everyone , I have a 2001 caddy Seville SLS , VIN-Y 4.6 , anyway , I have intermittent "change brake pads" come up on the dash. They are very low (front and back) , but I just cant remember if the sensors need to be changed every time the pads are changed. Any help ????? Thanks , Tim
    kingjay's Avatar
    kingjay is offline Cadillac Owners Member
    Automobile(s): 1999 Seville SLS, 2007 STS-4 V.6
    Nov 2012
    Bonita Springs, FL
    26
    72
    I believe that they do.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The sensors are sacrificial, so whichever one/s worn through will have to be replaced. You could also just take the two sensor wires and splice them together if you don't need the warning function.
    blancaclaudia is offline Cadillac Owners Member
    Automobile(s): 2002 STS w/ F55
    Feb 2013
    Tucson, Arizona
    72
    63
    Re: brake sensors
    As stated previously, the sensors are sacrificial. Very likely that they'll need to be replaced if you are getting the message. Recently I replaced the bearing/hub assembly on the front of my 2002 STS. No messages on the dash, and no other indications that the pads needed replacement. The sensors were just being "touched". Obviously, I replaced the pads. Personally, I would always rather replace the pads than the rotor. Ceramic pads were $50 for the fronts.
    If your car is approaching 100K, replace the wheel bearing/hub assembly at the same time as these will soon need to be replaced (100K is about the max life). $150 parts for the pair. Otherwise, you'll be duplicating the cost for labor.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,274
    Re: brake sensors
    Brake pad wear circuit - it's a series circuit, so one sensor wears (you don't know which one) and the message shows.
    They are sacrificial - simply a piece of wire embedded in a phenolic puck - when the wire wears through, the circuit opens. If you're a conscientious owner and do regular maintenance checks you don't need the crutch - check pad wear when you rotate your tires. My EBC Redstuff rear pads did not have the sensor cutout so I bundled the (good) sensor wiring and wire-tied it to the suspension arm.
    Different types for different years. Call Chris in parts at Rippy Cadillac over there >>>>>>>>>>
  8. Remove Advertisements
