RAPIE Module replaced, no RAP function
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, RAPIE Module replaced, no RAP function in Past Cadillac Vehicle Discussion; The Car: 1992 Seville, 4.9L PFI Below I have pasted a copy of a TSB issued for my Seville. It ...
    Zynder is offline Cadillac Owners Member
    Automobile(s): 1992 Seville 4.9L 230k+ miles
    Jun 2013
    TN
    17
    Below I have pasted a copy of a TSB issued for my Seville. It was experiencing this problem and so I replaced the RAPIE module with the one listed. This has fixed the flashing interior light/battery drain problem but now I have absolutely no RAP function. When turning the key to off, all systems shut down like an old non-RAP car would. All items function normally when the car is running. Placing the ignition switch into ACC also powers everything normally. All I did for this fix was unplug the old module and plug in the "new" one I got from a junkyard. I can't rule out a bad RAPIE module, it was used afterall, but I don't have another to test with. Or is part of the "fix" the new module incorporates is to just disable RAP function? I'd like RAP to be functional.
    ----BEGIN TSB----
    SUBJECT:
    INTERIOR LIGHTS CYCLE ON/OFF OR INOPERATIVE ILLUMINATED ENTRY
    MODELS AFFECTED:
    1992 ELDORADOS AND SEVILLES
    This bulletin supersedes Service bulletins T-92-3 and T-92-115 which should be discarded. This bulletin is being revised to correct one of the Labor Operations
    The 1992 Eldorados and Sevilles built before the VIN breakpoint and equipped with the first generation RAPIE module listed below, will continuously turn on the interior lights for a timed cycle, turn them off, and then back on if the door handle/RKE input is shorted to ground causing a discharged battery.
    The 1992 Eldorados and Sevilles built after the VIN breakpoint or equipped with the second generation RAPIE module listed below, will disable the illuminated entry feature if the door handle/RKE input is shorted continuously to ground.
    VIN Breakpoint
    Eldorado .............. 608125Seville ................ 810997
    RAPIE P/N
    2nd Generation ........... 12135007
    Parts are currently available from GMSPO.
    To diagnose these conditions check for a short to ground at the RAPIE module terminal A7. Refer to Service Information Manual Section 8A-114 for circuit diagram, and Section 8A-201-32, Figure A for component location. The short to ground may be caused by a shorted door handle switch (P/N 16626131), malfunctioning RKE module, or circuit 157.
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    Re: RAPIE Module replaced, no RAP function
    I doubt the fix was to disable RAP. Have you checked the relays associated with RAP. Later years have 2, one behind seat and another under drivers door sill towards front. Not sure exactly how many you have or where they are.
    Since the RAP cuts the ground I would check the grounds also, probably behind the seat also.
    The other thing that comes to mind is part # you swapped in, was it the same?
    Jun 2013
    TN
    17
    Ya know you are probably right about the relays. The module fix was supposed to be just disabling of the door handle switches if they stayed grounded all the time. So that's why I got confused there. But the car did sit with the window stuck partially down for quite along time. The rain leaked in there and I had to repair or replace almost every piece of electronics in the driver door. That relay being below there is probably soaked and I didn't even think about that. Thanks. The RAPIE module I replaced is the same number that is in the TSB which of course is a different PN than OEM for 1992.
