Oil Level
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, Oil Level in Past Cadillac Vehicle Discussion; Hi guys, Dumb question but thought it is best to ask the experts, I think after my last oil change, ...
    Amir A's Avatar
    Amir A is offline Cadillac Owners Member
    Automobile(s): 2003 Seville SLS 115K mi, 2008 Dodge Charger 45K mi
    Apr 2013
    Glendale, CA
    57
    53
    Oil Level
    Hi guys, Dumb question but thought it is best to ask the experts, I think after my last oil change, the guy put a little too much oil on my car, it is about 3 or 4 millimeters above max on the hash mark on the dipstick, will this harm the engine? should I have it drained a bit? thanks in advanced to any opinion.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    Re: Oil Level
    sounds like someone dumped in 8 full quarts -
    will it "HURT" anything - NO -
    do you need to drain some out - again NO -
    it will probably "burn off" that "extra" oil fairly quickly -
    the proper FULL mark -
    is in the middle of the hash marks -
    you are better off with 7 quarts - than 8 -
    if I don't change the oil myself -
    I tell the shop to just put 7 quarts in it -
    rather than the 7.5 the book calls for -
    Amir A's Avatar
    Apr 2013
    Glendale, CA
    57
    53
    Re: Oil Level
    Thank you basscatt, the car had a small oil leak before the oil change, now when I park it on down hill surfaces there are four oil drippings on the ground, but not on level surfaces, do you think that might be because of excessive oil?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Excess oil won't cause a leak.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,685
    Re: Oil Level
    at least not with the amount we are talking about in your car -
    69
    82,266
    Re: Oil Level
    Oil level is not THAT critical. If it where, the dipstick would not have an "acceptable range".
    Absolutely not.
    Amir A's Avatar
    Apr 2013
    Glendale, CA
    57
    53
    Re: Oil Level
    I am just puzzled why the oil leak increased after the oil change. I had him go underneath and check out the oil filter, it was completely dry.
    69
    82,266
    Re: Oil Level
    Maybe they spilled some oil when filling it and it is sitting in the lower air deflector.
    Amir A's Avatar
    Apr 2013
    Glendale, CA
    57
    53
    Re: Oil Level
    It did burn off the excess oil, now it is at top of hash mark and the leaks stopped, if it gets to the bottom of the hash mark, do I add 1 quart or half a quart?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    Re: Oil Level
    Let it get to here -
    <== ADD XXXXXXXXXX = OPERATING RANGE ====================00============================ ====O
    and keep it there. Check every 2 weeks - forget the DIC message - do it correctly. Don't simply dump in "a quart or two". Pour in 8 ounces or so, let it settle and check the level. Once you become familiar with doing routine underhood checks, a simple oil level check will become second nature.
    Your engine takes exactly 7.5 quarts of oil with filter - that amount will fill it to the level shown on my dipstick graphic ^^^.
    Did you ever read the article on oil consumption up ^^^ in the Cadillac Technical Archive - way up in the top black bar ???
    ......... and in your original post on the oil change, 3 or 4 mm high is close to 3/8" to 1/4" overfilled. Too much.
    Amir A's Avatar
    Apr 2013
    Glendale, CA
    57
    53
    Re: Oil Level
    Thank you Sub, I will read it.
  14. Remove Advertisements
