93 STS spark plug not firing
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, 93 STS spark plug not firing in Past Cadillac Vehicle Discussion; Hi i got a 93 sts that had a little miss then i noticed smoke out of the exhaust very ...
    decimatedsouls is offline Cadillac Owners Member
    Automobile(s): 93 cadillac seville sts
    Jun 2013
    37
    4
    Hi i got a 93 sts that had a little miss then i noticed smoke out of the exhaust very rich fuel odor so i pulled the plugs and 1 of them was soaked in gas so i cleaned the plugs and then replaced the plug wires the car ran great for about 20 minutes on a test drve then started acting up again and the plug was gas soaked again. Bad plug or maybe coil pack not delivering good spark any ideas
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: 93 STS spark plug not firing
    If your STS has the Northstar engine it's probably time for new spark plug wires - the expensive AC Delco set from RockAuto - and a thorough coil and ICM cleaning. Check the ICM ground wire and its terminals also.
    Use the diagrams in my albums for proper spark plug - coil wire hookup.
    Don't overlook the possibility of a sticky fuel injector. In addition to the plug wires and coil cleaning you might want to run a 20 oz. jug of Chevron TECHRON through a tank of Top Tier gasoline. (Google both - top tier gasoline and chevron techron .)
    Ranger is online now Cadillac Owners Member
    69
    82,384
    1 wet plug? Sounds like you have one not firing. Gotta be a bad plug, wire or coil.
    Jun 2013
    37
    4
    Hi my 93 seville sts has the 4.6 northstar i put new wires on cleaned up the coil pack plugs and grounds the icm
    Is clean and grounds are good and coil is new still the same cylinder is not firing and plug gas soaked so i swapped
    The plug with another the car ran good for a few min then started missing again checked plugs again the same cylinder
    Is still not firing even with a different plug new wires and new coil??? Is the icm bad i thought if the icm was bad
    None of the plugs would fire
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Not sure I'm following. Did you swap a couple wires too?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    Quote Originally Posted by decimatedsouls View Post
    after all you have done -
    I think you have a fuel injector stuck open -
    and dumping so much raw fuel the spark plug CAN'T fire -
    with the engine running -
    use a stethoscope - or something similar -
    and listen to each injector -
    you should hear a strong rhythmatic clicking - from each one -
    next would be to measure the resistance of each one with a DVM -
    69
    82,384
    Jun 2013
    37
    4
    Thanks for the reply i got it fixed it was a bad injector runs like a champ but now im having a charging issue
    93 sts 4.6 acdelco alt is about 1 year old and the battery about the same both have been bench tested about 5x and are good but when i start the engine it reads 11.5volts if i rev the engine up one time the volts jump up to 13.5 to 14.2 and its normally good all day when i start it up and shut it off, every so often when i start it up after work it does the same thing 11.5 till i rev it up one time then 13.5 to 14.2 even when the battery is under a load, grounds and wires all good any thoughts? And where does that little red alt wire go after it disappears into the wire harness to the dash or in the engine compartment somewhere thats the only wire i havent been able to inspect?
    69
    82,384
    Just an educated guess, but that sounds suspiciously like an alternator problem.
    Jun 2013
    37
    4
    Yeah thats what i thought but its been tested multiple times on and off the car and tests fine still trying to figure out where that little red alt wire goes if it goes to the dash or the engine compartment
    Feb 2006
    57,148
    Somehow the alternator is missing the excitation voltage signal at engine start - that voltage what "starts' the alternator/regulator. You need a charging circuit diagram.
    Many modified cars (and boat engines) use a one-wire alternator - they must be revved to about 1500 engine rpm to "start" - after that they're fine for the rest of that trip. You can find them in any hot rod or speed parts catalog.
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    Same thing here, figured that the regulator wiring is somewhat sensible, thin wires... Learned to live with it, no charge at stoplights and ok when above 900 rpm.
  15. Remove Advertisements
