2002 el dorado PCM 0734 code
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 el dorado PCM 0734 code in Past Cadillac Vehicle Discussion; Hello; I am new to the site so I hope I am in the right area. I am getting the ...
    tonyz is offline Cadillac Owners Member
    Automobile(s): 2002 el dorado ETC
    Jun 2013
    Live in Cottonwood, Ca.
    7
    I am getting the PCM 0734 code which indicates a 4th gear issue. I had the car checked at the dealer and at a transmission shop. Both said nothing wrong with the transmission and the code was cleared. This done about 2000 miles ago. Now the code is back, the transmission shop says it is an electrical issue.
    Anyone have an idea what I should check next, as to wiring harness or ground issue?
    Thank you;
    Tony
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Re: 2002 el dorado PCM 0734 code
    P 0734 - Incorrect 4th gear ratio. Unless someone has been inside the transmission (mechanical change) that IS an odd one.
    You can pull and clear your own codes: The car has a perfectly functional built-in scanner/reader/memory. Study the proper year group and procedures in the sticky post just above this thread - "How to pull codes". Then use the embedded link to get to definitions of all P,B,C, and U codes. Whether any found code is Current or History is necessary info to post here, too - as well as all definitions for found codes. We don't have all several hundred codes memorized - yet !
    Jun 2013
    7
    Thank you for the information. I pulled up the codes the other day, and did see some history codes. I will get them and post them tomorrow. Forgot to mention, the car has 45K and by records I have, no one has been in the transmission.
    Thank you agin;
    Tony
    Jun 2013
    7
    Here are the history codes:
    SDM1152 has to do with air bag
    TCS1283 vehicle stability enhancement system.
    TCS1186 same as above
    U1300 low voltage. Cause was the battery being disconnected.
    After reading the sticky on how to pull up the codes, I am confused as to how to clear the history codes.
    Thanks again;
    Tony
    Feb 2006
    55,850
    At the end of the alphabetical list of modules - the scrolling after each module codes display -- is there a "clear codes" option ? If so, hit "YES".
    Jun 2013
    7
    The clear codes option does not appear.
  9. Remove Advertisements
