Trouble codes
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Trouble codes in Past Cadillac Vehicle Discussion; Got to codes from cadillac dealership for my 1995 seville sts. I can find them so maybe someone on here ...
    chewy_likea_nut is offline Cadillac Owners Member
    Automobile(s): 1995 STS
    Nov 2012
    46
    Trouble codes
    Got to codes from cadillac dealership for my 1995 seville sts. I can find them so maybe someone on here can help me...codes are
    B200
    EL200
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Those don't look right. I assume you've read the sticky on pulling DTCs? Pull them yourself, and use the link provided for definitions.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,634
    Re: Trouble codes
    Those will be 4-character OBD-1 codes - a capital letter followed by 3 digits.
    Nov 2012
    46
    I got the code po36 Egr valve pintle position out of rang. Do i need to get new egr to fix? Also can this hurt my engine or anything if i let it go for a couple weeks tell i get paid?
    69
    82,190
    Re: Trouble codes
    No need to replace the expensive EGR valve. Just give it a good cleaning. Pretty sure there is a tutorial in the Tech Tips section. All it should cost is some time and a can of TB or carb cleaner.
    Timing is not urgent.
    Nov 2012
    46
    Ok cause my service engine soon light came on and that is the newest code i got. Oh and iv also been getting po110 general L-terminal circuit problem. Is that my alternator, a bad ground or something else?
  9. Remove Advertisements
