94 seville traction control
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 94 seville traction control in Past Cadillac Vehicle Discussion; I had to disable the traction control for an emissions/smog check. I was lucky enough to find a you tube ...
    capttut1 is offline Cadillac Owners Member
    Automobile(s): 1994 seville sls
    Jan 2012
    carlsbad, ca
    69
    I was lucky enough to find a you tube video while at the inspection shop with directions on the disable process.
    Question 1
    How do I turn the traction control back on.
    Question 2
    Do I really need traction control in Southern Cali.
    My Seville passed smog 124700 miles last major service 117000 everything from plugs/wires to PCV valve.
    I will post the exact emission results on Monday for analysis and comments.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: 94 seville traction control
    How did you disable?
    The only way I know on a '94 is pull the ABS fuse.
    If that's what you did, put the fuse in & clear ABS codes.
    They use a dyno for emissions check?
    NY used a dyno years ago & cars without a traction button were exempt, just idle test.
    69
    82,188
    Question 1
    Reverse what you did to disable it.
    Question 2
    Probably not.
    Jan 2012
    carlsbad, ca
    69
    here is the you tube video
    http://www.youtube.com/watch?v=U4fmJWc3i90
    I'm not sure how to reverse the procedure
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It goes back to normal after several ignition cycles.
    Jan 2012
    carlsbad, ca
    69
    Several usually means more than 2. So far after the disable T/C 2 ignition cycles. This car will sit for the weekend I'll report back next week if and when the T/C engages.
    Jan 2012
    carlsbad, ca
    69
    I'm no longer getting Traction Control Disabled message. I did not have to reset anything. An excellent video for diabling the system for the purpose of smog testing.
  10. Remove Advertisements
