1999 Eldorado A/C Compressor INOP
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 Eldorado A/C Compressor INOP in Past Cadillac Vehicle Discussion; Hi, Trying to help my grandfather out. He has a 1999 eldorado ETC and the ac compressor doesn't work. He ...
    Ryan96 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Jul 2012
    67
    Hi,
    Trying to help my grandfather out. He has a 1999 eldorado ETC and the ac compressor doesn't work. He would like to know if anyone has a pin out for the fuse block under the good. He is trying to locate D-3, and D-1 pins Thanks
    Thank
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,559
    Re: 1999 Eldorado
    tell your grandfather to check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    there might be a simple reason the AC compressor does not run -
    like it is low on freon - which would set a code -
    Jul 2012
    67
    We cleared the codes already, no current codes present. But thank you for the info
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: 1999 Eldorado
    The B1348 Code will fire and disable to AC compressor to keep it from damaging itself. Clear that code and see if the clutch engages..next step would be to check the hi and lo pressure switches imo
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: 1999 Eldorado
    No codes & no "Low Refridg" message?
    Could be a blown fuse.
    Check AC comp fuse. If blown, and new fuse blows, bad comp clutch.
    "Cruise" fuse powers low press switch but should throw a code.
    Jul 2012
    67
    Re: 1999 Eldorado
    We cleared the codes through the on-board diagnostic center. There are no codes present. My grandfather jumped the pins in the under the hood fuse block in an attempt to get the a/c compressor working to no avail. Maybe we are not clearing the codes properly? Turn the car to run( one click before start) Hold "OFF, and PASS Warmer" until the bulb test comes on. Then it will read the codes, after all the codes have been read it says Codes, FAN UP for yes, then PCM Codes, FAN DOWN for no, the FAN UP once more( I don't remember the exact procedure, I have my phone in the car on the DTC Sticky from the form) Is this the proper procedure?
    Quote Originally Posted by Aztec ETC ECS View Post
    He does have the "Low Refridg Message, however no codes appear in the on-board diagnostics.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: 1999 Eldorado
    See if this helps
    Feb 2012
    NYC
    50
    1,948
    Re: 1999 Eldorado
    Could just be low.
    Jul 2012
    67
    Re: 1999 Eldorado
    Could just be low.
    Would the low refridg cause the a/c compressor to not engage even after jumping the pins.
    I am sorry for making the more long and drawn out then it has to be.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: 1999 Eldorado
    Quote Originally Posted by Ryan96 View Post
    If it ran low, the B1348 code will fire and the compressor will then be disabled.
    Jul 2012
    67
    Re: 1999 Eldorado
    All of the symptoms seem to be leading towards the a/c compressor being at fault. The car doesn't have the B1348 code, so it seems like the
    compressor is the culprit. I will post results after changing the a/c compressor. Thank You for all of the help
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: 1999 Eldorado
    Follow the diagnostic troubleshooting tree i posted before diggin in. That's a bitch of a job..but if you're going to do so.
    here are the steps:
    1. Recover refrigerant from A/C system.
    2. Serpentine drive belt.
    3. Right tire and wheel assembly.
    4. Compressor splash shield.
    5. Engine splash shield and retainer.
    6. Oil filter.
    7. Oil cooler lines at oil filter adapter.
    8. Compressor electrical connection.
    9. One bolt securing compressor inlet and outlet line fitting.
    10. Compressor from mounting bracket.
    11. Mounting bracket and brace from engine.
    Install or Connect
    1. Compressor mounting bracket to vehicle.
    Tighten
    • Front bracket bolts 44 N.m (32 lb. ft.) .
    • Rear Bracket stud(s) 24 N.m (18 lb. ft.) .
    • Rear bracket nuts 31 N.m (23 lb. ft.) .
    1. Compressor to vehicle.
    Tighten
    • Rear mounting bolts 24 N.m (18 lb. ft.) .
    • Front mounting bolts 47 N.m (35 lb. ft.) .
    1. Compressor inlet and outlet line fitting.
    Tighten
    • Compressor line fitting bolt to 33 N.m (24 lb. ft.) .
    1. Compressor electrical connection.
    2. Oil cooler lines at oil filter adapter.
    3. Oil filter.
    4. Compressor and engine splash shields.
    5. Tire and wheel assembly.
      • Lower vehicle.
    1. Serpentine drive belt.
    2. Evacuate and charge system.
    3. Leak test all refigerant connections.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,559
    Re: 1999 Eldorado
    I STRONGLY believe you are jumping to the wrong conclusion -
    you said he got the LOW REFRIGERANT message on the DIC -
    then you SHOULD also have the B1348 code -
    if you only read the "P" codes - maybe you missed it -
    like Vincent said in post #10 -
    if this code is present - the compressor will not run -
    one thing you might try BRIEFLY - is to jumper the LOW PRESSURE SWITCH -
    just to see if THAT will allow the compressor to run -
    CAUTION - do NOT allow the compressor to run IF the system is low on freon -
    freon carries the oil that lubricates the compressor -
    without oil - you WILL destroy the compressor VERY QUICKLY -
  16. #14
    Jul 2012
    67
    Re: 1999 Eldorado
    I just checked, no B1348 codes present, or in history. A/C compressor will still not turn on.
  17. #15
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: 1999 Eldorado
    Check fuses
  18. Remove Advertisements
