Key fob transmitters - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Key fob transmitters in Past Cadillac Vehicle Discussion; Originally Posted by rodnok01 Bypass vats and then you can use any key. Hardest part is laying on your back ...
  1. #31
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by rodnok01
    Bypass vats and then you can use any key. Hardest part is laying on your back under dash.
    I usually take my shoes off, fully recline the seat, and lay upside down when working under a dash. A pillow helps.
  2. #32
    consigliori's Avatar
    consigliori is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Triple Black Eldorado ETC, 98 ETC(HG), 91 Seville(gone)
    Nov 2006
    Annexia
    43
    395
    There's no need to -
    vats keys are cheap man
  3. #33
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Re: Key fob transmitters
    all you need now is your blanky -
    and you're all set for a little nap -
  5. #34
    Nov 2006
    Annexia
    43
    395
    Here ya go,
    finished & fully functional-
    Not bad - I'm happy with it : ) It's not crazy bulky to carry in your pocket, and you can't even see it in the ignition while driving (at least I can't anyway)
    I've only been using it for a couple days but so far there's been zero issues or problems. Fun little project for about 20 bucks & time spent.
    I had cut the rough draft key first using needle files to match it to my ignition key, and it turned out great - worked perfectly.
    Then I screwed up the correct valve vats blank when cutting it into a keyblade, of course. Thought I was going to end up bypassing vats after all,
    but I just put the resistor pellet from the key I messed up into the one I had already cut - no problemo
    I wanted the button layout piece flush with the case but wasn't sure if I'd be able to pull that off and have it look alright.
    I wish I would've cut it a little longer to cover up the empty button at the bottom too. Havn't figured out what to do with that yet-
    And I suppose the key could be a bit shorter-
    I never thought about it but I use the ear/tab things to turn the cylinder also, not the key. I still can, but it's a little different motion.
    And there's totally enough room in there for the door key, and have it able to slide in and out from the bottom, once I figure out the best way to do it
  6. #35
    Sep 2010
    East Boston MA.
    29
    26,325
    That actually looks pretty good considering the two totally different designs and plastics.
  7. #36
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Looks good.
  8. Remove Advertisements
