Front strut compression - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Cadillac Seville / Cadillac Eldorado Forum Discussion, Front strut compression in Past Cadillac Vehicle Discussion; Alright so it seems like some of you are saying to push the strut up and the push the lower ...
  1. #16
    hamwinkie is offline Cadillac Owners Member
    Automobile(s): '99 Seville STS
    May 2011
    Seattle, WA
    22
    50
    Re: Front strut compression
    Alright so it seems like some of you are saying to push the strut up and the push the lower control arm down at the same time. I will try this tomorrow morning and let you know how it works.
  2. #17
    May 2011
    Seattle, WA
    22
    50
    Alright I just took the strut off and took a few pictures for you guys.
  3. #18
    May 2011
    Seattle, WA
    22
    50
    Alright I think the strut is done for because when I compressed the springs and took off the top mount, the plastic deterioted. It is from the part the nut goes game off. And when I went to put it back together I had to lean the spring pretty far to the side to be able to get the strut back thru the spring. Plus the top of the strut kept falling down and I had to pull it back up to be able to connect. So would this be a suitable replacement? Strut And do I have to replace all 4 of them to passive or can I just change this one because I want to keep the cost to a minimum.
  5. #19
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,706
    that is NOT how I would do it -
    but if you decide to use that unit - you MUST replace BOTH front struts -
  6. #20
    May 2011
    Seattle, WA
    22
    50
    Quote Originally Posted by basscatt View Post
    Thank you for your quick response and correct me if I'm wrong but you're saying to stay with the active suspension. Now would this be a suitable replacement?
    Active Strut
    Number 2
    Number 3
    Number 4
  7. #21
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Used shocks/struts are a complete waste of money. They're just as old as the ones getting replaced, and you won't know if they're good or not until after you install them.
    If you're looking for the cheap way out, just buy 2 new passive struts, and install resistors to keep the computer happy.
  8. #22
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    ebay? local wrecking yard is good too. so is strut mount bad or actual strut shaft bent? why replace strut if mount is bad? you got pics. take off strut. take off mount. what do they look like? you can easily separate all the parts since you got spring compressor
  9. #23
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    This situation is too confusing to give advice. If you need to replace the struts, plural, don't replace just one, then check out the recent threads on the subject. Different options are covered. Pretty expensive lesson no doubt.
  10. #24
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,706
    NO - I have absolutely no problem with changing to the PASSIVE struts -
    in fact - I usually recommend them - the $$$$$$$ difference is staggering -
    and the vast majority would never notice the difference -
    especially on a 14 year old car - with 100,000+ miles on it -
    there are some parts that just aren't worth replacing with junk yard parts -
    struts and shocks are at the top of that list - with few exceptions -
    GENERALLY SPEAKING -
    shocks and struts with 100,000+ miles are about shot -
    at minimum - they are "well-worn" - if not worn-out -
    I suppose - in your case - in a real pinch -
    you could buy 1 junk yard strut - and use the bearing plate -
    and spring seats - or whatever else is screwed up -
    but retain the original spring and strut -
    the PROPER solution would be to replace BOTH front struts -
    I would go with Monroe 71684 - $64 each -
    and Monroe 902972 upper mounts - $51 each -
    both available through amazon.com
    along with a couple resistors to "fool" the electronics -
    good luck - and keep us posted -
  11. #25
    EcSTSatic's Avatar
    Dec 2004
    Wichita, KS
    5,212
    Did you ever get this fixed? I have pairs of front and rear struts/shocks minus the springs that you can have for the cost of shipping. They came off my ''99 STS with 117K miles. Not throwing codes, just typical wear.
  12. #26
    May 2011
    Seattle, WA
    22
    50
    Quote Originally Posted by EcSTSatic View Post
    WOW thanks but I actually just ordered a strut from a local junkyard yesterday that I'm going to be picking up tomorrow. If it doesn't work out I will definitely let you know. And here are a few pictures for you guys to scratch your head at.
    This is when the spring is just sitting on the lower rubber mount.
    Side angle of it.
  13. #27
    Aug 2007
    mpls mn
    2,527
    should strut extend with no top mount?
  14. #28
    May 2011
    Seattle, WA
    22
    50
    Alright CadiForums I finally get her back on the road. I just decided to hire someone to fix it because I don't have the time right now with finals... So to fix it they took a crow bar and jammed it in the lower control arm and pushed down and bam it was lining up perfectly. But of course that wasn't the end of everything because when I had the car jacked up I noticed that there was only 1 lugnut on the passenger hub! So I got a new hub and installed it and now I'm getting the alignment done at the shop. Everything's looking good for now. Thanks for the help everyone.
  15. #29
    Aug 2007
    mpls mn
    2,527
    Crowbar repair? If it does not move with little hammer, use bigger hammer?
  16. #30
    May 2011
    Seattle, WA
    22
    50
    Quote Originally Posted by stoveguyy View Post
    Pretty much it was a 3 foot crowbar with a pipe added to the end. Life's a whole lot easier with some big hammers.
  17. Remove Advertisements
