Brown gunk caked around radiator cap and filler neck - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Cadillac Seville / Cadillac Eldorado Forum Discussion, Brown gunk caked around radiator cap and filler neck in Past Cadillac Vehicle Discussion; Do you know for sure that the contamination on that cap came from the junkyard radiator and not your engine? ...
  1. #16
    69
    82,287
    Re: Brown gunk caked around radiator cap and filler neck
    Do you know for sure that the contamination on that cap came from the junkyard radiator and not your engine? Either way, flush the cooling system and don't loose any sleep over it.
  2. #17
    lorain is offline Cadillac Owners Member
    Automobile(s): Seville
    May 2013
    20
    Sorry for a late bump repost. Flushed the entire system twice with straight tap water and refilled a third time with antifreeze. Cap is brand new. Coolant still turning brown and gunk still accumulating around filler neck and bottom of cap. Also of note, some shiny flakes like you would find in flaked paint and what appeared to some kind of grey silicone-looking material (but that's not what it was, still have no idea) came out with the flushing.
  3. #18
    blancaclaudia is offline Cadillac Owners Member
    Automobile(s): 2002 STS w/ F55
    Feb 2013
    Tucson, Arizona
    73
    63
    Proper cooling is critical without gunk is necessary for any engine but critical for a Northstar.
    Flush the gunk out of the entire cooling system and replace the radiator with a new one. Radiators wear out and have to be replaced; gunk circulating around will shorten the life of all of the components of the cooling system and other problems will soon surface + you'll be replacing your used radiator soon.
    Unfortunately, you'll eat the cost and labor to install a used radiator but you'll be much better off with new in the long run.
    I don't know the best and least expensive source for a new radiator for a Northstar because I haven't had to replace mine yet but I'm sure that other posters will come in with recommendations.
  5. #19
    69
    82,287
    Someone put some type of magic potion in the cooling system or, if it just started after installing the "new" radiator it's in the junk yard radiator you installed. I don't suppose it can hurt too much and since it has already been introduced to your cooling system, just flush out what you can and move on.
  6. Remove Advertisements
