Not to sure, minor over-heat problem 03 STS
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Cadillac Seville / Cadillac Eldorado Forum Discussion, Not to sure, minor over-heat problem 03 STS in Past Cadillac Vehicle Discussion; My 03 STS in the summer time seems to pass the 12 o'clock water-temp mark on warm/hot days, especially in ...
    ahmaduhhs's Avatar
    ahmaduhhs is offline Cadillac Owners Fanatic
    Automobile(s): 2011 STS, 2003 Cadillac Seville STS
    May 2007
    Indiana
    270
    My 03 STS in the summer time seems to pass the 12 o'clock water-temp mark on warm/hot days, especially in stop and go traffic. Last summer I flushed the raditor and removed and checked/washed the surge tank, and cap. Once flush was done(2X) add Dex-cool. What should i check next, the previous owner had a shop replace his water pump at around 60k, car now has 72k. I would love to resolve this before it gets hot, and summer rolls around.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    How much is it passing it? A needle's width or less? If so, perfectly normal.
    Sep 2010
    East Boston MA.
    29
    26,325
    Please don't double post. Check your thread.
    ahmaduhhs's Avatar
    May 2007
    Indiana
    270
    Re: Over heating problems on a STS northstar.
    Sorry mate, though of starting a new thread after i sent this.
    Replying on the newer thread after this.
    ahmaduhhs's Avatar
    May 2007
    Indiana
    270
    Re: Not to sure, minor over-heat problem 03 STS
    Needle and a half, but seems to move(hot) when stopped in traffic, and as i press the gas to start moving, it seems to level back to near the 12 mark. Is it that okay?
    Want to keep the car running well, since i am driving it a lot more these days.
    Sep 2010
    East Boston MA.
    29
    26,325
    Hot day, in traffic, with the A/C on? Normal.
    ahmaduhhs's Avatar
    May 2007
    Indiana
    270
    It is not hot here yet, but if i recall it correctly it fluctuates even with the a/c off.
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you check the purge line when you changed the coolant?
    Sep 2010
    East Boston MA.
    29
    26,325
    No need to apologize.
    ahmaduhhs's Avatar
    May 2007
    Indiana
    270
    Sure did, Went as far as removing and rinsing out the surge tank and all associated hoses.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    This is within perfect running conditions. As the ambient temperature rises in the summer, you will see this often. Check out the sticky "engine cooling fans operation explained" thread on the Northstar engine forum.
    ahmaduhhs's Avatar
    May 2007
    Indiana
    270
    Thank you for the quick reply, how could I tell if the water pump is running at its optiaml, not sure if the shop/previous owner used a GM wp.
    Quote Originally Posted by maeng9981 View Post
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    The engine and cooling system is operating normally. Drive the car.
    If the temperature gauge DID NOT move in heavy traffic something would be wrong.
    As advised, read the temperature gauge and cooling system operation stickies in Engines, Northstar Performance.
    I moved your other posts from the hijacked thread. Go back and read this entire thread again.
  16. #14
    69
    82,162
    Quote Originally Posted by ahmaduhhs View Post
    If the belt tensioner is not slipping and the belt (pump) is spinning, it is working as designed.
  17. #15
    ahmaduhhs's Avatar
    May 2007
    Indiana
    270
    Belt is spinning, not really sure how I should check that tensioner?
  18. Remove Advertisements
