1999 Seville STS. Blows Cold on Passenger, but Warm on Drivers! ?
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 Seville STS. Blows Cold on Passenger, but Warm on Drivers! ? in Past Cadillac Vehicle Discussion; I am having problems with my a/c. On the drivers side, it blows hot air regardless of temperature. Ive read ...
    sixx__ is offline Cadillac Owners Member
    May 2013
    3
    I am having problems with my a/c. On the drivers side, it blows hot air regardless of temperature. Ive read that it might be the Blend Door Actuator.. How do i check if i need to completely replace the part? Ive read that you can manually shift the door so that it blows cold air? Please help. Thabks in Advance
    69
    82,286
    Re: 1999 Seville STS. Blows Cold on Passenger, but Warm on Drivers! ?
    Pull the DTC's. See the DTC Sticky if you need help. If you have an actuator failure, you'll have a code for it.
    P.S.
    Don't forget to post the code definitions along with the codes.
    May 2013
    3
    @Ranger how do i pull the codes? Sorry its my first car
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Read the "sticky" thread on how to pull DTCs, at the top of the Eldorado/Seville page.
    BTW,
    rundunnyrun's Avatar
    rundunnyrun is offline Cadillac Owners Member
    Automobile(s): 1998 Eldorado ETC
    May 2013
    Terre haute, In.
    36
    My son figured this one out for me. You have to take the panel off in the back of the glove box. He reached his arm in there and turned the actuator by hand. It sticks occasionally, and at the time, I did not have the money to take it some where and have the dash took apart !!
    May 2013
    3
    History :
    C1223, C1225, C1227, C1234, C1234, C1255, C1291, U1056, U1064, B1652, B1341, B1344, B1652, P0603, P1258, P1376, P1574, P1599, P1611, U1255, U1000, C1783, C1785
    Current:
    IPM B1340, IPM B1343, PCM P1660, RSS C1738
    Quote Originally Posted by rundunnyrun View Post
    Thats what im trying to figure out meanwhile. I dont have the cash to but a new part if it is necessary to buy one. Nd i had read that you can just manually turn the door by hand so it only blows cold air. Thats what i need for, meanwhile. Im going to give it a try see how it goes.. thankyou
    Sep 2010
    East Boston MA.
    29
    26,323
    Codes are meaningless without definitions.
  10. Remove Advertisements
