Installing new Alpine 138BT Head Unit
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Installing new Alpine 138BT Head Unit in Past Cadillac Vehicle Discussion; General question about head units. I actually have two harnesses that seem to work. One uses RCA connectors to the ...
    tziady is offline Cadillac Owners Member
    Automobile(s): 1995 STS
    May 2013
    43
    13
    General question about head units. I actually have two harnesses that seem to work. One uses RCA connectors to the Alpine 138BT that I am installing and one uses regular wires. I know that the RCA on the Alpine is a 4v Pre-out. Is it better to use the harness with the RCA as compared to the one that uses the speaker connections (white, white/black, green, green/black, purple, purple/black, ect)?
    Thanks allot in advance for the information,
    PS: one advantage I see about using the speaker wires is the ability to use noise reducers (esp. base reducers) on those lines. Would this be an issue for using one over the other?
    May 2013
    43
    13
    I am installing a new Alpine 138BT. General question about head units. I actually have two harnesses that seem to work. One uses RCA connectors to the Alpine 138BT that I am installing and one uses regular wires. I know that the RCA on the Alpine is a 4v Pre-out. Is it better to use the harness with the RCA as compared to the one that uses the speaker connections (white, white/black, green, green/black, purple, purple/black, ect)?
    PSS: can anyone suggest a good path to run the wires to the front dash? Back seat then run along the sides or the middle?
    Thanks allot...
    T
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Do you have the Bose system? If so, you'll need an integration module, which I believe has RCA connectors.
    Wiring can be run down the sides, no need to run it down the center.
    Sep 2010
    East Boston MA.
    29
    26,323
    tziady, this is the third thread you've posted the same question in. Please don't double/triple post. Keep it in the thread you started.
    Sep 2010
    East Boston MA.
    29
    26,323
    Yes, starting the new thread was the right thing to do, but you posted in two other places too . When you post in more than one place, questions/answers get missed, and it takes longer for you to get an answer.
    May 2013
    43
    13
    Re: 1995 STS Speedometer / odometer issue
    oh....I am sorry about that. I did not realize that I did multiple post. Tired posting error. Sorry...
    T
    bwv565 is offline Cadillac Owners Enthusiast
    Automobile(s): HAD a miserable Catera and even worse 2003 STS
    Jan 2013
    Toronto
    603
    Re: Installing new Alpine 138BT Head Unit
    If you buy from Crutchfield, they send you the wiring harness and complete installation instructions as well as tell you if it's even compatible with your vehicle for free. THey will also walk you through the installation over the phone if you need help. Just a thought.
  10. Remove Advertisements
