head holes enlarge
Results 1 to 7 of 7
Like Tree2Likes
  • 4 Post By MoistCabbage
Cadillac Seville / Cadillac Eldorado Forum Discussion, head holes enlarge in Past Cadillac Vehicle Discussion; Hi Could be possible to enlarge tha head holes (holes where the engine block bolts pass by to clamp the ...
    lambocadillac is offline Cadillac Owners Member
    Automobile(s): northstar
    Jun 2011
    36
    head holes enlarge
    Hi
    Could be possible to enlarge tha head holes (holes where the engine block bolts pass by to clamp the heads... they are 20). If so how much, I'm planning to enlarge the holes to 5/8"
    Regards
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Repairing the pulled threads does require enlarging the holes.... in the block. They are then tapped to accept inserts or studs.
    There is at least one person enlarging the holes in the head, and using larger bolts as a cheaper alternative, but I wouldn't do it, or recommend it.
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    Re: head holes enlarge
    If I was going to do that much work to remove the engine and take the heads off, I would want to do it right with thread inserts.
    69
    82,190
    Why do you want to enlarge the holes in the head?
    Sep 2010
    East Boston MA.
    29
    26,325
    I would assume to use larger head bolts.
    69
    82,190
    That's what inserts or studs do without the extra drilling. Seems like a lot of extra work for nothing.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,634
    ........ and you get into the business of calculating proper torque settings for the larger diameter (and metallurgy) of the new bolts ............
  10. Remove Advertisements
