Right rear upper control arm.
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Right rear upper control arm. in Past Cadillac Vehicle Discussion; Heard a squeaking sound coming from the rear of my Eldo. Real noticeable when you push up and down on ...
    92WHTSTS's Avatar
    92WHTSTS is offline Cadillac Owners Fanatic
    Automobile(s): 99 Eldorado ETC
    Jan 2011
    277
    Heard a squeaking sound coming from the rear of my Eldo. Real noticeable when you push up and down on the rear, had it diagnosed, tech said it was a bad rear upper control arm, bushings are rotted out. The whole control arm needs replacing. Checked out prices and it costs $750.00 dollars for a new one from the stealership. My question is does anyone have a reputable place where I can purchase this part without the high cost? And would it be advisable to purchase a used one?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,864
    Re: Right rear upper control arm.
    No upper control arm ? Lower traiing arm, rear knuckle alignment link, shock absorber with height control bladder, separate sway bar (squeaky when bushings go).
    Talk to Chris in parts at Rippy Cadillac over there - business hours, EDT.
    For parts blowup, get into www.gmpartsgiant.com, your car, system, specific system. A text page will open - upper left is a "more info" tab that opens a parts blowup keyed to the text page.
    92WHTSTS's Avatar
    Jan 2011
    277
    Thx for the reply Sub, but mine has a upper control arm just like number 3, was wondering if I can get away with just replacing all the bushings instead of the whole assembly.
    txtaz is offline Cadillac Owners Fanatic
    Automobile(s): 72,92,02 Eldorado
    Jan 2013
    55
    185
    The Eldo does have a rear upper control arm.
    Part Giant has them for $552 and based on what I've read, everyone has just replace them. Can't get bushings individually.
    When I ever get time, I plan on getting an upper and lower from the junk yard and matching bushings to fit. I'm thinking they are pressed in and I've always wanted a bearing press.
    I need to go with a combination of poly and rubber since I added ~300lbs of DynoMatting to the car and need to stiffen it up a bit.
    So far I know there are polys are available for some of them.
    I'll post results when I get to it, hopefully sometime this year.
    Taz
    92WHTSTS's Avatar
    Jan 2011
    277
    Thx for the reply txtaz. I was thinking of doing the same, finding one from a salvage yard, and having the bushings pressed in from a machine shop. However, the place I deal with says they don't install used parts, only new ones. It's ridiculous to me to have to buy the whole assembly for that amount of money.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Make sure that the problem isn't actually the ball joints in the knuckle, where the control arm attaches. It's a much more likely suspect, and is not part of a new control arm assembly...
    92WHTSTS's Avatar
    Jan 2011
    277
    Quote Originally Posted by drewsdeville View Post
    I was shown by the tech, it's both bushings in each end of the upper control arm as shown in the illustration number 4.
    Oct 2004
    Oak Creek, WI
    5,609
    Ok good deal
  11. Remove Advertisements
