1995 STS Speedometer / odometer issue
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By curtc
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1995 STS Speedometer / odometer issue in Past Cadillac Vehicle Discussion; Hello all; I just purchased a 1995 Cadillac Seville STS. The speedometer mostly does not work. About 95% of the ...
    tziady is offline Cadillac Owners Member
    Automobile(s): 1995 STS
    May 2013
    43
    13
    Hello all;
    I just purchased a 1995 Cadillac Seville STS. The speedometer mostly does not work. About 95% of the time, it does not work. Additionally, the trip function as well as the odometer seem to not work. Occasionally, the speedometer will work for a few seconds here and there while driving. At first, I thought it worked with I accelerated heavily; but that was just an unfounded impression. Anyway, during those times, it seems that the odometer and the trip work.
    Can someone suggest what things I need to check that might be the source of this problem?
    Any suggestions would be welcome.
    Thanks in advance,
    Tamer
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,915
    Re: 1995 STS Speedometer / odometer issue
    First place to check is the VSS (Vehicle Speed Sensor) - located on top of the right transmission output shaft extension - just about in front of where a passenger's right toes would point.
    Either the electrical connector or the (Hall effect) VSS itself.
    How to's down in Discussions, Item Specific; Cadillac Tech Tips. Locator diagram in my albums - The Community tab ^^^, Albums, the red Seville. 2 albums, 118 pictures/graphs/diagrams. (mostly for 2000 and later, but mechanical location is OK)
    Next place is a diagnostic of the DIC (Driver Information Center)(instrument panel module). Talk to N*Caddy in this forum. He'll see this, probably today.
    Study the sticky post just above this one - "How to pull codes" - to find out how to get stored diagnostic trouble codes from your car's built-in code reader/scanner/memory.
    May 2013
    43
    13
    Submariner;
    Thanks for the replay.
    Quote Originally Posted by Submariner409 View Post
    How to's down in Discussions, Item Specific; Cadillac Tech Tips. Locator diagram in my albums - The Community tab ^^^, Albums, the red Seville. 2 albums, 118 pictures/graphs/diagrams. (mostly for 2000 and later, but mechanical location is OK).
    ************ I will check this out right away. I am hoping to change out my stereo this weekend; so that will give me a little bit of time to check this out.
    I have ran the codes twice and only get historic codes and no new codes. I will also try this again to see if any new codes are there; but I know that there currently aren't any.
    Thanks so much this gives me at least a place to start looking.
    TZiady
    Feb 2006
    55,915
    Do some deep, deep research on the horrors and nightmares of changing a sound system HU that is part of the car's serial data bus and TheftLock system.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Changing the HU is totally doable, just takes the correct adapter harnesses and some car audio know how. I would advise letting a professional do it...And by that I mean NOT Best Buy or any other large chain electronics store, an actual car audio shop...I had mine done and it worked flawlessly for the 5 years I owned the car.
    tziady and tziady like this.
    May 2013
    43
    13
    I have worked with computers and electronics for the past 15 years. I have managed large datacenters full of complex electronic systems and devices. I have successfully changed out two factory audio systems with aftermarket alpine systems in the past. One in a honda passport and the other in a 300zx. It is always a challenge; however, I enjoy it and worse case scenario; I know a very good audio shop that can help me out if I end up messing up anything really badly. I have no issues messing and working with electronics. I will not touch breaks, engine, or other safety items. I have both the trunk adapter harness (but will try to avoid using it since I have no idea how to run it well from there to the dash as well as a dash adapter harness. Finally, if all else fails; I will use the thread in this forum of just connecting to the HU an AUX cord - worse case scenario. I really would love to use my blue tooth enabled alpine and microphone with my phone. Also, will make way for a future installation of a double din nav system with all the bells and whistles; when I can afford the $800 price tag. Finally, I have found that crutchfield support is spectacular along with great resources of people like yourselves. Anyway, plan on it this weekend. Will take pictures and let you all know how it goes.
    Cheers,
    T
  9. Remove Advertisements
