1967 Eldorado Update
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1967 Eldorado Update in Past Cadillac Vehicle Discussion; I didn't do much in the winter being busy with school and just to cold to work but in the ...
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    I didn't do much in the winter being busy with school and just to cold to work but in the last week I have gotten a lot accomplished. First thing is I discover why it wont start. No spark, tested to coil and found that it is bad. I have gotten a new coil that I will put on tomorrow. I believe that the original failed because of age and a bad ground to the distributor. I found that the car does have ALC just not hooked up to the compressor but with a manual air filler behind the license plate. The final and most important thing is that I finally did a compression test today. I only did a dry test and was actually surprised by the results.
    1-130 psi
    2-144 psi
    3-125 psi
    4-146 psi
    5-115 psi
    6-105 psi
    7-145 psi
    8-131 psi
    I triple checked every cylinder and found that they had way better compression than I thought.
    Also when cranking the fuel pump started pumping. I was expecting nasty black floaty stuff but what came out was just some nice clean older gas. Not the best gas but good enough that I'm going to use it in the lawn mower.
    I plan to have it running tomorrow. Ill make sure to have a video for that.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: 1967 Eldorado Update
    That engine should have more like 160-175 lbs. After it's running, check it hot w/the carb wide open.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,274
    Quote Originally Posted by Aztec ETC ECS View Post
    That I want to see .................... (He'll be OK with some oil film back up in the cylinders.)
    Squirt a half teaspoon of oil into each (no spark plug) cylinder and roll the engine a few times - before you even attempt to start it.
    Feb 2012
    NYC
    49
    1,948
    Let me clarify so nothing terrible happens. After the engine is running & hot, shut it off, unplug the coil, open the carb wide & check it.
    Better?
    13ir14314's Avatar
    Jan 2012
    Minnesota
    22
    443
    Thanks for the advise guys. I put a teaspoon of trany fluid in the cylinders to soak. I used trany fluid because of the high detergents to remove any dirt and carbon from the rings. I will remove as much of that oil as I can tonight if it hasn't all leaked past the rings.
    Like I said that was a dry compression test with absolutely no oil up in the cylinders and rings. Those readings are a little low and scattered but I plan on a full rebuild at some point but for now I just want it to run.
    Should I also do a leak down test or is the compression test enough?
    13ir14314's Avatar
    Jan 2012
    Minnesota
    22
    443
    She's alive. Got a new coil sprayed a little starter fluid in it and with the flick of the key it was running. Sorry I didn't video it as I was to excited to get it running. Sounded great.
    The power steering work great as did the power brakes. What I was most impressed by was the vacuum locks work and hold their vacuum.
    However all great things must come to an end. I was curious how close the timing was and when hooking up my light to the battery I heard some strange noise and by moving the main wiring harness I could repeat. Disconnected the battery followed the wires and sure enough the main cable going the the starter was laying against the exhaust manifold.
    The alternator and all wiring in that area have been replaced by a person that should have nothing to do with cars. Any idea how the main power cable to the starter is supposed to be routed?
  9. Remove Advertisements
