Horn Help
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, Horn Help in Past Cadillac Vehicle Discussion; My 1999 Seville has no horn. All fuses are fine. The connections are fine. The horn sounds when I press ...
    cmbiz1 is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS, 1987 Sedan Deville (FWD)
    Apr 2013
    Washington, DC
    28
    Horn Help
    My 1999 Seville has no horn. All fuses are fine. The connections are fine. The horn sounds when I press the door lock button on the remote. I thought it was the clock spring but the airbag light is not on. Because the clock spring is an expensive part, I hoping to be able to start elsewhere first but, I am open to any suggestions. Any help will be appreciated!
    Thanks,
    Vic
    69
    82,161
    Re: Horn Help
    If it works with the remote, but not from the airbag, then the problem has to be in the airbag or the contacts right below it in the column.
