2000 STS idling rough
Results 1 to 8 of 8
Like Tree1Likes
  • 2 Post By Ranger
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2000 STS idling rough in Past Cadillac Vehicle Discussion; I have a 2000 Seville sts 4.6 I keep getting a misfire #7 code I've swapped plugs,wires,injectors,coil packs and I'm ...
    stealth92 is offline Cadillac Owners Member
    May 2013
    4
    I have a 2000 Seville sts 4.6 I keep getting a misfire #7 code I've swapped plugs,wires,injectors,coil packs and I'm still getting code for misfire any suggestions would be greatly appreciated thanks
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: 2000 seville idling rough
    You'd have better luck in the Seville section of CF, this is the 05+ STS area...totally different.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Bump !! and move to the proper Seville forum .........
    68
    81,891
    Quote Originally Posted by stealth92 View Post
    There are no wires. How'd you do that?
    When was the TB last cleaned?
    98cadillac and 98cadillac like this.
    lorain is offline Cadillac Owners Member
    Automobile(s): Seville
    May 2013
    20
    No wires? Is it coil over plug? I'd swap the coil pack with another and see if the misfire changes location.
    68
    81,891
    Yes. GM went to COP ignition on the Northstar in 2000.
    Buster28 is offline Cadillac Owners Member
    Automobile(s): 2000 ETC 18K miles, 1991 Allante 11K miles, 1996 ETC (sold)
    Sep 2010
    RI
    23
    I have observed that on the GM service website and my 2000 FSM there are no OBDII single cylinder misfire codes (P0301-P0308) applicable to 2000-2003 (LD8) and (L37) engines, the only misfire code is P0300, so I am not certain how a #7 misfire DTC is being set.
    There are no individual coils packs on 2000-2003 LD8/L37 engines, they are in a cassette consisting of 4 coils each. The front and rear cassettes are interchangeable but without single cylinder misfire detection you still don't know where the problem is.
    Feb 2006
    55,850
    Re: 2000 STS idling rough
    Many aftermarket and parts dealer scan tools will give a definite cylinder misfire readout - "P 0302 C" or "P 0307 H".
    That little ICM uses a (don't quote me) 14 or 18 pin connector.
    More pictures of all this in my albums.
  11. Remove Advertisements
