Bad clunk when depressing brake pedal
Results 1 to 12 of 12
Like Tree4Likes
  • 2 Post By Submariner409
  • 2 Post By wlewis
  • 2 Post By Ranger
Cadillac Seville / Cadillac Eldorado Forum Discussion, Bad clunk when depressing brake pedal in Past Cadillac Vehicle Discussion; Hi I recently purchased a 99 sts with 188k on the body... the entire car is nearly mint but I ...
    jamesjohnsonair is offline Cadillac Owners Member
    Automobile(s): 99 STS
    May 2013
    32
    6
    Hi I recently purchased a 99 sts with 188k on the body... the entire car is nearly mint but I have come upon some suspension issues lately.... the problem is that every once in a while when I hit the brakes there is a loud clunk or bang as if the brakes are clamping to tightly too soon... I was told that there is a common problem with the caliper bracket bolts... does anyone else have any Ideas? also I am getting a click/popping noise when turning the wheel at a stand still and a good rattle up front at low speeds I believe they are three seperate issues but i thought I would mention them just in case.... I have also heard bad motor mounts may cause a "clunking" any thoughts?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: Bad clunk when depressing brake
    Welcome Aboard !!!
    The braking "clunk" ......... front or rear ? If it's in/near the front end you may have a damaged front center motor mount - the entire drivetrain cradle mount system flexes when the brakes are applied .......... Open the hood, engine idling in P. Left foot on the brakes, right on the gas. Shift to D, holding the brakes, and bring the engine up to 1200 - 1500 rpm. Does it rock back toward the firewall more than 3/4" ? If so, suspect that center mount. Not that it would/might be the entire problem, but it would be contributory.
    wlewis is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado
    May 2011
    31
    Rattle at low speeds could be worn stabilizer bar links. I just replaced them on my 99 eldorado for the same reason. Replacements for my car were about $21 a piece at autozone.
    68
    81,887
    Re: Bad clunk when depressing brake pedal
    Step one would be an inspection.
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    Do Sevilles even have stabilizer bar links?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes. No other way to connect the bar to the knuckles.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Motor mounts are good to check, as well as the forward control arm bushings.
    Feb 2013
    306
    Ok, I must have been getting it confused with the torque struts.
    Sep 2010
    East Boston MA.
    29
    26,325
    Ah. No, '98-'04 Sevilles don't have torque struts.
    May 2013
    32
    6
    I definitely have a bad front mount which i will be replacing next week and I will update either way
    control arms are bad too!
    Can anyone post an explode diagram of front and rear suspension for me?
    Feb 2006
    55,840
    You NEED a real GM service manual - either from eBay or www.helminc.com. For instant gratification (service manual) plus a LOT more (so much that you have to learn the site inside and out) subscribe the car to www.alldatadiy.com
    Leave the Haynes and Chilton on the store shelves. Far, far, far too generic for your needs.
    There are special procedures and torque values for almost every suspension/brake part. Use the manual.
    thu and thu like this.
    68
    81,887
  15. Remove Advertisements
