P0452 - EVAP system pressure control sensor
Results 1 to 15 of 15
Like Tree1Likes
  • 2 Post By Ranger
Cadillac Seville / Cadillac Eldorado Forum Discussion, P0452 - EVAP system pressure control sensor in Past Cadillac Vehicle Discussion; I have a 99 Seville STS with 135,000 miles. I'm getting a code today. P0452-Evaporative Emission Control System Pressure Sensor ...
    netjr5555 is offline Cadillac Owners Member
    Automobile(s): 99 STS
    Apr 2013
    55
    88
    P0452-Evaporative Emission Control System Pressure Sensor Low Input
    I read on here that something is wrong with the fuel pump module multi-pin electrical connector or wiring. If you agree, where is this module located so I can take a look at it. Thanks in advanced for your help.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,169
    Re: P0452
    In your car, if there is no access hatch in the trunk floor just forward of the spare tire well, you need to drop the fuel tank to reach the module electrical connector.
    Google "cadillac forums seville fuel pump module replacement" or somethimng close, always prefixed by "cadillac forums ................".
    69
    82,393
    Re: P0452
    Wait. I think the '99 DOES have an access panel in the trunk.
    Apr 2013
    55
    88
    Re: P0452
    Ok. There is a panel in the trunk floor forward of the spare tire well about the size of a basketball fastened by 5 bolts. I'm a bit confused so please bare with me. The car is running great so I'm not looking to replace the fuel pump. Correct? I'm just looking for a bad connector or wire that is causing the 0452 code. Correct?
    69
    82,393
    Re: P0452
    That's the access panel.
    No, you do not need to replace the fuel pump, but I am not sure what that code is for. Maybe the tank pressure sensor? See what some of the other guys have to say.
    netjr5555 and netjr5555 like this.
    Apr 2013
    55
    88
    Re: P0452
    I got this description from engine-codes.com which is different than sticky. P0452 CADILLAC Fuel Tank Pressure Sensor Circuit Low Voltage. Ranger is right! Now what am I looking for? And where? I'm sorry guys. One little code is making me feel stupid. Trust me, a donation to this site from me is coming soon. I appreciate your help.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Same definition, different wording. The tank pressure sensor is part of the EVAP system.
    The sensor is on top of the pressure sensor.
    Apr 2013
    55
    88
    Re: P0452
    OK. Tell me if I have this right in my head. The tank pressure sensor is on top of gas tank. I need to trace wiring from sensor and look for open/shorted harness or bad wire. Correct?
    Sep 2010
    East Boston MA.
    29
    26,323
    No. The sensor is on the pump assembly, IN the tank.
    I would suspect a bad sensor before a wiring problem.
    Feb 2006
    57,169
    Re: P0452
    Here's what you'll see when you remove the access panel for the fuel pump module - "module": Fuel pump, hoses, strainer, fuel level sender, fuel tank pressure sensor, electrical connection.
    Apr 2013
    55
    88
    Re: P0452 - EVAP system pressure control sensor
    Thanks Submariner! I'm going to change FTP sensor today and see if P0452 goes away. I'll let everyone know.
    Apr 2013
    55
    88
    I replaced the FTP sensor today ($40). Pretty simple since I have an access panel. I drove about 15 miles and the check engine light hasn't came on. In the past, it would come on every 2-3 days so I'll know if it's fixed soon. I'll post my results in a few days. Thanks guys!
    Apr 2013
    55
    88
    I've driven a tank of gas since replacing FTP sensor and P0452 hasn't came back so it definitely fixed it.
  16. #14
    9302Eldug is offline Cadillac Owners Fanatic
    Automobile(s): 93 and 02 Eldorado
    Apr 2012
    Oakley CA
    60
    226
    Actually pretty odd for one of those units to go bad!
  17. #15
    Feb 2006
    57,169
    The 1998 - 2002 series (Seville ???) had a recall for just that sensor - recall # 03038.
    The white sticker is the fulfillment info for my car .......
  18. Remove Advertisements
