Orifice tube orientation, 1999 STS
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Orifice tube orientation, 1999 STS in Past Cadillac Vehicle Discussion; When we removed the orifice tube, stupid me didn't note the orientation. The posts that I found while searching referenced ...
    knon2000 is offline Cadillac Owners Member
    Automobile(s): 2005 STS 2009 CTS
    Sep 2009
    49
    48
    When we removed the orifice tube, stupid me didn't note the orientation. The posts that I found while searching referenced the brake booster, which in the 99 STS, it is not in line with the AC line containing the orifice tube. Can anybody remember which end faces the radiator?
    Right now, I have it installed with the arrow pointing away from the radiator. Long end towards the firewall. Is that correct? Seems like it isn't cooling like it should and we flushed it thoroughly.
    The compressor puts a load on the motor that seems excessive, and the cooling lines shake abit. When we originally put in the Freon, it was quiet, didn't have what I thought was an excessive load. Right now it seems to "tick" when running, and I know it isn't the belt, and it didn't do that when we put the compressor in on Friday.
    I was just thinking maybe I had the orifice tube in wrong, or that maybe it got clogged up with debris that we missed, although I rather doubt that.
    68
    82,082
    Re: Orifice tube Orientation, 1999 Cadillac STS
    I assume the arrow points in the direction of refrigerant flow. If so, this should help.
    http://autoacrepairs.com/OTSFlow.html
    Sep 2009
    49
    48
    Thanks for that
    It would appear that I have it in correct
    Guess I need to look at it to make sure that it isn't covered with debris.
    68
    82,082
    Was there any debris on the old one when you removed it? If not, then this one should be fine.
    grkid89 is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS Northstar 32 Valve V8
    Oct 2009
    Florida
    76
    I have the same question. I put the short side (with the arrow) into the low pressure side. Did I install it in right?
    However, when I took the old orifice tube to replace, the new one I bought doesn't fit. So I just used the old one.
    68
    82,082
    Re: Orifice tube orientation, 1999 STS
    I assume you viewed the link in post #2?
    Oct 2009
    Florida
    76
    Yes, I did, but not completely understanding it.
    I'm assuming the side with the arrow goes into the low pressure side, and the filter facing into the high pressure side.
    In any case, I think I put it in the right way according to the link in post #2.
    68
    82,082
    Quote Originally Posted by grkid89 View Post
    Correct.
    The orifice tube is where it changes from high pressure to low pressure so the arrow would point in the direction of the low pressure side which is also the direction of refrigerant flow.
  11. Remove Advertisements
