What could make cooling fans not work
Results 1 to 14 of 14
Cadillac Seville / Cadillac Eldorado Forum Discussion, What could make cooling fans not work in Past Cadillac Vehicle Discussion; I have a 1997 cadillac sts and the cooling fans won't work even if i turn on the air conditioner ...
    tezepremillz is offline Cadillac Owners Member
    Automobile(s): 1997 CADILLAC SEVILLE
    Apr 2013
    24
    10
    I have a 1997 cadillac sts and the cooling fans won't work even if i turn on the air conditioner still won't come on the car over heats still won't come on. I changed the relays the tempeture sensor fans still won't come on. i had it put on a machine at auto zone i got a code the code is p1660 "cooling fan circuit fault"
    it says probable cause " open or short circuit condition in the driver circuit or failed cooling fan relay" please help me and would this be expensive to fix i love my cadillac..
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Have you checked the fuses?
    You don't need to go to AutoZone to have your codes pulled. You can do it through the DIC. See the 'sticky" thread at the top of the Eldorado/Seville page on how to do so.
    Apr 2013
    24
    10
    Re: What could make cooling fans not work
    yeah i replace my cooling fan fuse still no luck
    Sep 2010
    East Boston MA.
    29
    26,325
    Next step is looking for wire or connector damage.
    rodnok01's Avatar
    Feb 2012
    NC
    6,625
    I would also check to see if you apply 12volt directly to fans if they operate to see if they are actually good. As a short term fix you could wire them to run all the time until you can figure out the issue. If you do hot wire them put a fuse in the wire. The relays are in an area that gets alot of corrosion, it's possible the relay connectors and or wiring are corroded and bad.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Check the AC fuse and/or relay. That's where the fan control circuit gets power from.
    Has any other work recently been done on the front of the engine?
    There is a ground wire for the fans on the left front of engine. It could disconnected or broken.
    If you can't find it, ground the black wire on the right side fan, not the left side. The right side is the one with a black & light blue wire. The left side has a black & white (not this one).
    But there is a fan circuit code. Can the PCM pick up a fault in the high amp circuit or just a break in the low amp or control circuit? Anyone?
    Apr 2013
    24
    10
    i know nothing about wiring i'm scared to do that
    Feb 2012
    NYC
    49
    1,948
    Quote Originally Posted by tezepremillz View Post
    How'bout the first part- Check the AC fuse and/or relay. That's where the fan control circuit gets power from.
    And if the second part is necessary, you may present it to the professionals.
    Apr 2013
    24
    10
    when you say it might be wiring do you mean wiring to the actual fan ? or the relay wiring ? where would i buy the wires to my fans what would they be called
    Buster28 is offline Cadillac Owners Member
    Automobile(s): 2000 ETC 18K miles, 1991 Allante 11K miles, 1996 ETC (sold)
    Sep 2010
    RI
    23
    1997 E/K body DTC P1660 is a Quad Driver Module 1 Output failure. A Quad Driver is a an electronic switch used to control relays, solenoids, etc. Typically the +12 Vdc operating voltage is supplied to the device and the Quad Driver supplies the ground to complete the circuit. In this instance the Quad Driver is located on the Powertrain Control Module (PCM) and is used to control the fans. However, the Quad Driver is not controlling the fans directly because they draw too much current. Instead the Quad Driver controls the relays that switch power to the fans when energized. Therefore, the problem involves the fan control relays and not the fans. The relays receive +12 Vdc from the AC compressor fuse.
    Apr 2013
    24
    10
    Was that English or spanish? i didn't understand any of that. i replaced the relays they still won't come on i change the fuses still won't come on. is there a way i could test the fans without hot wiring. could it be the switch? how much would estimate the repair of wiring would cost
    so are you saying i have to replace the pcm? that thing is expensive very expensive could i use one off ebay that's like used? and how much would it cost to have it programmed
    the ac comp fuse was bad you think that could make them come on?
    Feb 2012
    NYC
    49
    1,948
    That's what I've been saying.
    If it continues to pop, you have a shorted comp clutch.
    It shouldn't pop with the AC off.
    Apr 2013
    24
    10
    thank you so much i pulled the fuse and it was burnt old and dusty and crusty. i put a new one and omg they came on at top speed i really appreciate. it's my first cadillac i love it so much wooo thanks alot man
  16. #14
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    If you intend to keep this car and keep it in top shape, get the Factory Service Manual (FSM) from Helm, Inc (www.helminc.com). You'll be glad you did. Also, you might find used copies on eBay.
  17. Remove Advertisements
