VATS Problem
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, VATS Problem in Past Cadillac Vehicle Discussion; Tried to start 93 this morning, Got the STARTING DISABLED DUE TO ANTI THEFT message. Tried diffrent key with same ...
    9302Eldug is offline Cadillac Owners Fanatic
    Automobile(s): 93 and 02 Eldorado
    Apr 2012
    Oakley CA
    60
    224
    UnhappyVATS Problem
    Tried to start 93 this morning, Got the STARTING DISABLED DUE TO ANTI THEFT message. Tried diffrent key with same result. Gonna check resistance at harness connector with key in in the morning and do the resistor deal if needed, but my question is if not the wiring in the steering collum problem what is the next most likely culprit? VATS module failure? I know, check the codes.
    RJ
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by 9302Eldug
    Yup.
    Apr 2012
    Oakley CA
    60
    224
    Re: VATS Problem
    Did the resistor bypass this morning, everything fine now. Did not want to go to Radio Shack so I went thru my resistor stash and started measuring and found the combination that was needed !
