Air Conditioner problem on my 1997 STS - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Like Tree4Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Air Conditioner problem on my 1997 STS in Past Cadillac Vehicle Discussion; I got nothin' Now excuse me while I go put out an electrical fire....
  1. #16
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: Air Conditioner problem on my 1997 STS
    I got nothin'
  2. #17
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Quote Originally Posted by Subsailor613 View Post
    Thank you for sharing , what you consider a Knowledge base.
    If moisture was NOT an issue, why do we install filter/DRYERS ?
    My knowledge is NOT based on a web site, but classroom knowledge, and
    over 40 years in the trade, both, Automotive and Refrigeration/Air Conditioning.
    I am sorry you NEVER came across a Manual-Resettable Low Pressure Switch,
    OH Yeah, there is NONE on your desktop !
    "NONSENSE", i haven't heard that since 8th grade.
    I agree with your reasons, but,that is NOT the only reason.
    It seems you have evaded the original members Post,
    and chose to occupy this forum with member bashing .
    Have a Nice day.
    FIRST - this is a Cadillac forum -
    so I limited the pertinent information to AUTOMOTIVE APPLICATIONS -
    not houses - boats - walk-in coolers - jet planes - or factories -
    in AUTOMOTIVE APPLICATIONS -
    I have NEVER seen a mechanically resettable AC pressure switch -
    so - based on the TENS-OF-THOUSANDS
    of AUTOMOTIVE AC systems I have serviced -
    without running across one single unit -
    I am going to stick my neck out and say -
    "mechanically resettable AC pressure switches do not exist -
    in AUTOMOTIVE AC SYSTEMS" -
    until someone lists an application - to prove me wrong -
    I was simply TRYING to be nice/gentle with you -
    NONSENSE seemed to be the most appropriate word to use -
    WHERE did THAT come from?
    WHO said moisture was NOT an issue?
    moisture contaminates freon -
    anyone with at least the fundamentals of AC systems would know that -
    THAT is a BRILLIANT statement -
    PLEASE - list just ONE SINGLE CAR - up to the 2005 model year - that used one -
    PLEASE - PLEASE - PLEASE - PROVE ME WRONG -
    on the contrary -
    I gave the OP the very best answer that could be given -
    with the information he supplied -
    CHECK FOR CODES -
    if the system WAS low -
    a CODE would be set -
    if there was a defective pressure switch - a CODE would be set -
    if YOU knew anything about AC systems in Cadillacs -
    YOU would have/SHOULD have come to the came conclusion -and my post #8 was the CORRECT answer to the OP's question -
    of "How do I reset the Low Pressure Switch?"
    I would hardly call CORRECTING YOUR MIS-INFORMATION -
    MEMBER BASHING -
    and if you post more MIS-INFORMATION -
    you can EXPECT to see me CHALLENGE YOU - AGAIN -
    just as I would expect to be challenged -
    if I posted MIS-INFORMATION -
  3. #18
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Have a Nice day !
  5. #19
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Have a Nice day !
    and you do the same!
  6. #20
    Feb 2012
    NYC
    49
    1,948
    Anyhow, I'm pretty sure compressor meltdown from the lack of suspended oil is far worse than a little moisture in the system. A 20 min pull down should remove most of it.
    If your mechanic doesn't know how to reset the AC codes in a Cadi, I suggest you find a new one.
    Any more questions, Scoobydo?
    Post edited by Submariner409.
  7. #21
    Feb 2012
    NYC
    49
    1,948
    Here it comes...ready?
    You're not gonna believe but just do it.
    Check the "CRUISE" fuse (or wiring) underhood.
  8. Remove Advertisements
