Upgrade/ Alternator replacement 1993 ETC N*
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, Upgrade/ Alternator replacement 1993 ETC N* in Past Cadillac Vehicle Discussion; I know that the vehicle calls for a 140 amp alternator when it does not have the heated windshield but ...
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    QuestionUpgrade/ Alternator replacement 1993 ETC N*
    I know that the vehicle calls for a 140 amp alternator when it does not have the heated windshield but what I would like to do is install the 200 amp alternator that I can purchase from SummitRacing.
    http://www.summitracing.com/parts/mci-n8127-11
    My car has one wire that comes off the side of the alternator (plug in)
    This replacement alternator apparently has 2 wires coming out of the plug.
    I've upgraded the grille with one from a 99 (fit perfectly) and am in the process of installing the black interior (from headliner to carpeting) from the 99 and the only issue I have run into so far has been the need to swap out the wiring harness from the 93 into the 99 drivers seat.
    The other issue I'm facing is re-pinning the rear plug-in for the headliner (which will now give me the buuilt in garage door opener and the compass mirror.)
    The door panels from the 99 were pretty much plug-n-play as well, I did have to use the power door lock switch from the 93 in the 99 housing.
    All that aside, I'd really like the 200 amp alternator so that I can install a nice rich sound system using the factory head unit (non-bose)
    Please help
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,369
    Re: Upgrade/ Alternator replacement 1993 ETC N*
    Quote Originally Posted by Tankboy40 View Post
    Please help
    unless you are going to put in a giant amp of some sort -
    you don't need a giant alternator -
    Tankboy40's Avatar
    Jun 2012
    Akron Ohio
    44
    328
    Quote Originally Posted by basscatt View Post
    Thats not what I asked. I will put the "giant" alternator in because I want to.
    Now, I ask again, Does anyone know what I would have to do to make the 200 amp alternator work ?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    you found a high output alternator that fits in the northstar mounting location? not that an alternator housing is high tech or anything. you just bolt it on. so you do know that your new unit will fit? do you have it?
    Tankboy40's Avatar
    Jun 2012
    Akron Ohio
    44
    328
    i believe I found the right one. the Eldorado's (from what I've found) with the heated windshields use a 200 amp alternator.
    I dont doubt that it will fit the N* mounting location (considering its a N* option)
    I'm just wondering if it has a 1 wire plug or 2 wire plug.
    If it HAS a 2wire plug, where does the other wire go?
    I was hoping someone else has done this before.
    If not, I'll be the first and report back how it goes.
    Aug 2007
    mpls mn
    2,528
    Well, the limo cars had a dual alternator setup. That would be cool
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Here, w/heated windshield..
    X-Hibition is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Eldordo ETC Collector's Edition with Aux Input
    Aug 2011
    Outside Boise, ID
    100
    Tankboy, you have said both that the 200 amp alt has a two wire and a one wire connection. Which is true and how did you verify that?
    I went to Summit and looked at the two, 140 & 200 amp, choices for your 1993. When I went to Rock Auto they show different alts for the with or without heated windshield but both are listed at 140 amp. Inconsistent, yes, but you can't always trust catalogs.
    Best bet, call Summit and request someone pull the alt and verify connector. And if it is two, not one, then get a wiring schematic and answer your own question. Or wait and someone else may have the answer. Good luck.
    This is what I saw on Summit
    http://www.summitracing.com/search/y...and-generators
    scott f's Avatar
    scott f is offline Cadillac Owners Fanatic
    Automobile(s): 2002 STS/ 1994 STS
    Oct 2010
    Oshawa, Ont. Canada
    229
    My 94 has the heated windshield c/w 140a generator...that's what was factory installed
    Tankboy40's Avatar
    Jun 2012
    Akron Ohio
    44
    328
    ok... I'll let you know how it works out.
    Aug 2007
    mpls mn
    2,528
    Why does the pic of alt have multiple connectors? My small alt wire broke and caused much grief till I replaced plug. I looked at a few junkyard cars and most had a 4 pin plug with some cars having 2-3 wires. Not all were same. Never saw a 1 wire setup
    Tankboy40's Avatar
    Jun 2012
    Akron Ohio
    44
    328
    Quote Originally Posted by stoveguyy View Post
    Not sure, mine only has 1 wire coming out of the plug (its a '93 w/o heated w/s and IS OBD-I)
    My 99 ESC OBD-II has 2 wires coming out of the plug.
  15. Remove Advertisements
