Outcome of dealer service visit today re: steering wheel shake - Page 3
Closed Thread
Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 31 to 45 of 157
Like Tree42Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Outcome of dealer service visit today re: steering wheel shake in Past Cadillac Vehicle Discussion; Originally Posted by Mafiaman111 did anyone think of a simple alignment would solve the steering wheel shake ------------------------------------- an alignment ...
  1. #31
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: Outcome of dealer service visit today re: steering wheel shake
    Quote Originally Posted by Mafiaman111 View Post
    an alignment will NOT solve a shake or vibration -
    Tankboy40 and Tankboy40 like this.
    Quick reply to this message Reply
  2. #32
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    funny. a new set of tires is cheaper than 1 f55 strut. a vibration is different than looseness that you can feel in steering. vibration is probably due to bad tire or bent wheel. if you turn steering wheel quickly you can feel worn parts. inner/outer tie rods. maybe a bad rack. have front end checked by an independent garage. check alignment. are all tires wearing evenly? than inspect steering column for worn or loose u-joints.
  3. #33
    bwv565 is offline Cadillac Owners Enthusiast
    Automobile(s): HAD a miserable Catera and even worse 2003 STS
    Jan 2013
    Toronto
    603
    Quote Originally Posted by stoveguyy View Post
    The tires, I was told, are ok, and none of the wheels are bent. Every now and then, when I turn the steering wheel all the way to the left (like making a U-turn, for example), there is a grinding type of sound in the wheel/steering column, but it only happens with a very sharp full turn to the left, otherwise it doesn't make any sounds. I imagine this has something to do with worn parts, thereby giving the mechanic reason to tell me that it's the steering column that in fact does need replacement. The tie rod was just replaced in February (by a dealer), not sure about rack. Alignment was also performed in February (at same time as new brakes/rotors/pads/engine mount). I'm so confused my head is spinning, and how do I know who is telling me the true story?
    I'm going to speak to the mechanic at the garage across the street from me who told me that they are experienced in working on N* Caddys, although they do not have a road force balancing machine. I only wish I had someone to go with me who knows about these things and can help me figure out who is giving me the right information...or if I should get rid of the car.
  5. #34
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I would start with a road force balance, and while the rims are off, use a wire brush to remove any corrosion from the rim/rotor/hub mating surfaces.
  6. #35
    Aug 2007
    mpls mn
    2,528
    You should change ur info. North America is vague. Not that anyone is stalking you. So car rides fine at at speeds under 55mph?
  7. #36
    Jan 2013
    Toronto
    603
    I left the vehicle with Green Ross across the street from me. They are certified and they work on Caddys like this one all the time. They are going to do a thorough front end check and give me a second opinion. While they don't have a road force machine, he told me they have the latest technology balancing equipment. They will look at tires, wheels, balance, everything and give me a rundown for minimal cost, in terms of diagnosis and balancing. Depending on what they find, I'll take it from there. I feel like it's my child having open-heart surgery.
    The car rides like a Cadillac STS should at anything under about 112 km/hour, no shakes, no vibrations, nothing. Smooth as can be, fast, quiet, a true pleasure to drive.
  8. #37
    Aug 2007
    mpls mn
    2,528
    Oh, and tell them you don't want to replace the $600 each struts.
  9. #38
    Jan 2013
    Toronto
    603
    They have been advised not to do any repairs other than balancing without first contacting me.
  10. #39
    Aug 2007
    mpls mn
    2,528
    Well I meant to imply that struts are probably ok. But not a certainty. Parts do fail. I am sure you don't want to pay to replace them and find little or no change in ride. Usually you get a service suspension message and car rides fine but elec portion of strut is bad and only way to fix it is replace it. You have no messages. But you do have f55 stuff which is nice and the stabilitrak is tied into "system"
  11. #40
    Jan 2013
    Toronto
    603
    Exactamundo. Would the fact that at speeds under 110km/hr have no vibration issues be a good sign? I would think that if a major problem existed it would be consistent, regardless of speed. You SURE you don't want to make a trip to Toronto to help me out? The weather is nice now. )
  12. #41
    Sep 2010
    East Boston MA.
    29
    26,325
    That's right around the speed that the shimmy usually occurs in these cars.
    You don't have a major problem.
  13. #42
    Aug 2007
    mpls mn
    2,528
    Many folks replace tires and get no relief. Son bought 08 Infiniti G35 with crappy tires. He knew car was supposed to ride nice since all his friends like them. He got new tires and car is super smooth.
  14. #43
    Mr.electric is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2013
    80
    I know it can upset others on the forum when I say this but I would just ignore the vibration. As long as your safety items are ok
    - bearings
    - tires
    - ball joints
    - have I forgotten something?
    I have seen people spend thousands trying to pin down vibrations on luxury cars.
    Ex: my friend spent $2000 getting rubber mounts and rear drive shafts done on a 92 Lexus LS 400 to address a vibration only to find out the car is only worth $2000 for the whole car!
  15. #44
    Jan 2013
    Toronto
    603
    Quote Originally Posted by Mr.electric View Post
    - bearings
    - tires
    - ball joints
    Doesn't upset me at all, and in fact I appreciate it. I have thought about what if it's not possible to fix the problem. The car isn't worth more than your friend's Lexus, probably.
    Today I had the mechanic across the street do a balance and he inspected the wheels, rotors, brakes, etc and he said that 2 of the tires are 'getting there' but in the meantime he did the balancing, and as soon as I can get on the highway to test it out I'll have a better idea.
    He told me that if this didn't do the trick, and it turns out to indeed be the steering column, then there's no point in buying new tires. BTW I have Michelin Primacy MXV4s on the car; he said they're at least 5 years old.
    Now I need to get the CD players fixed, as well as the power windows.
  16. #45
    Sep 2010
    East Boston MA.
    29
    26,325
    - bearings
    - tires
    - ball joints
    Sometimes, what the car is worth just isn't the point. I know bwv's situation is different, but many owners of these cars (and other older luxury and performance cars) own them because they couldn't afford them new, or because they don't like any newer models any better (at least not the ones they can afford). Either way, they'll spend whatever is necessary to keep the cars running and driving as intended. Ask me, or N*Caddy what we've spent maintaining/repairing our $5K-$8K cars.
  17. Remove Advertisements
Closed Thread
