eldorado 98 dash sound - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 56
Like Tree3Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, eldorado 98 dash sound in Past Cadillac Vehicle Discussion; Originally Posted by MoistCabbage The blend doors are vacuum operated in the OPs car. They wouldn't make a continuous noise. ...
  1. #31
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,179
    Re: eldorado 98 dash sound
    No, they are electronic blend door actuators. Mode door actuators are vacuum powered, but controlled by an electronic switching module.
    And from my experience, they can get noisy.
  2. #32
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    Judging from my experience, if it is a problem with the blend doors it will usually set a code. Try pulling the codes (see the sticky at the top of this forum) and posting them here along with the definitions.
    You might want to check for someone's head "beatboxing" inside your glove compartment first.
  3. #33
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Guys, a squeaky door still opens and close as it should, is just making noise; that's it. Do not expect any code, it still works, it still controls the air mix as it always did.
  4. #34
    Feb 2013
    306
    I occasionally hear a 'fluttering' noise in my dash and I have intermittent codes relating to the blend door actuators.
  5. #35
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    If you have a vacuum leak, the blend door will not move properly, thus you get a code.
    If there is no vacuum leak, and all you hear is a squeak of the door as it move then you won't get a code.
    You have to make distinction between the kind of noise you hear, squeak or hiss.
  6. #36
    Feb 2013
    306
    Mine was like a bird flapping its wings under the dash for a couple of seconds rather than a hiss. I'm not an expert on it by any means, I just know it set a code.
  7. #37
    eldorado_sean's Avatar
    eldorado_sean is offline Cadillac Owners Enthusiast
    Automobile(s): 98' Eldorado ESC
    Sep 2012
    Burbank, California
    740
    My dash vents doesn't work properly either... when I turn on the fan on any mode or strength it ONLY flows to the front windshield defroster. I checked it about 3 times after I noticed and its the same. And to all ^^^^ this weekend ill take the glovebox out to find the source of the sound
  8. #38
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The front defrost is the DEFAULT position if you have no vacuum. So is 100% sure in your case is a vacuum leak.
    Before removing the glove box make sure your supply vacuum line (on the right side of the car going to the firewall) is intact, has no leak and the valve is mounted correctly (it only goes one way).
  9. #39
    Sep 2012
    Burbank, California
    740
    So right now I took out the glovebox and I tried to listen but the sound went away... I'm very stumped I'm not familiar with this stuff where is the vaccum line I should check and should I take another video/ pictures?
  10. #40
    Sep 2012
    Burbank, California
    740
    https://www.youtube.com/watch?v=Fwku...e_gdata_player that thing at the top is making the sound. My dad told me that the blower motor doesn't have enough power or somethings jamming it.
  11. #41
    Sep 2012
    Burbank, California
    740
    Quote Originally Posted by N*Caddy View Post
    Read it?
  12. #42
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Quote Originally Posted by eldorado_sean View Post
    Read it?
    actually -
    YOU ruled out ANY possibility of the sound having anything to do with vacuum -
    a long time ago -
    starting with post #12 -
    Key on engine off -YES
    verified on post #22 -
    Ignition on engine off - yes
    verified again on post #28
    Key on engine off- yes
    if the engine is OFF - there is no vacuum -
  13. #43
    Sep 2012
    Burbank, California
    740
    Whatever I said is the pure truth and what ever I said its what's happening. I just know that my vents are not working AND that thing on the top of the blower motor is making the sound I've been hearing. And any suggestions of what this is? And on post #28 I said engine on climate control off- yes
  14. #44
    Aug 2009
    North Carolina
    1,179
    Oh for crying out loud... we could have saved 2 pages of back-and-forth. As I mentioned long ago, and N* mentioned again, that part in your video is 1 of the 2 electronic blend door actuators. The blend doors on these cars are ELECTRONIC, not vacuum.
    If you have problems with air not coming out the correct vents, then that is a separate issue all together. Mode doors are vacuum actuated, controlled through the HVAC controller (right on firewall to the right of the duct in your video above). That box has electric valves to switch vacuum to the different doors. So the problem could be a loss of vacuum to the HVAC control box, or it could be the box itself. Broken manifold vac lines are very common issue and will affect the parking brake release as well.
  15. #45
    Feb 2013
    306
    Quote Originally Posted by mhamilton View Post
    ...Broken manifold vac lines are very common issue and will affect the parking brake release as well.
    I realize this thread is not about a parking brake release, but the 98 Eldorado parking brake release must be different from the 98 Seville, since the 98 Seville release is a solenoid.
  16. Remove Advertisements
