2002 STS Reverse Lights Not Working
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 STS Reverse Lights Not Working in Past Cadillac Vehicle Discussion; I replaced both bulbs and lights still aren't coming on. I put my finger on the relay and can feel ...
    ckeathley is offline Cadillac Owners Member
    Automobile(s): 2002 STS
    Feb 2013
    44
    I replaced both bulbs and lights still aren't coming on. I put my finger on the relay and can feel it pick up when shifted to Reverse. I am a little confused on which fuse is for the Reverse Lights. I checked the one that is labeled Neutral Safety Back Up, I'm not sure that is the right one. There isn't one labeled 'Reverse' . Any help is much appreciated.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,264
    Re: 2002 STS Reverse Lights Not Working
    Do the rest of the bulbs in the trunk mounted lighting panel work ? Some of this series of cars has had problems with either the wiring harness - where it exits the left trunk hinge bracket - or the ground point at the left fenderwell body metal.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by ckeathley View Post
    That is the correct fuse (10A, labeled NSBU).
    You could try borrowing a relay from another circuit as a double check.
    Feb 2013
    44
    I swapped with another relay and still no luck. All the other lights on the trunk mounted panel are working. I checked for voltage at the harness on the trunk lid (between the black and green wires) and I'm not getting anything. I'm just not sure what to do next???
    Sep 2003
    Metro ATL
    4,854
    If it was my car, I would start probing (with a sharp needle and a voltmeter) that light green wire in the trunk lid wire harness back to where it leaves the trunk lid through the LH hinge channel and is spliced into the body harness that leads to the underseat fuse/relay box.
  8. Remove Advertisements
