Need help with climate control
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Need help with climate control in Past Cadillac Vehicle Discussion; My a/c is blowing warm on the drivers side and I have no codes but based on what I've read ...
    dk1
    dk1 is offline Cadillac Owners Member
    Automobile(s): 01 Seville SLS
    Sep 2010
    West Hollywood
    48
    64
    My a/c is blowing warm on the drivers side and I have no codes but based on what I've read hear I removed the glove box and can see the actuator moving but I'm not really sure what I'm looking at. I was hoping to see a broken lever but the actuator shaft goes into this big box. Any input would be appreciated.
    Thanks guys.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,564
    Re: Need help with climate control
    Quote Originally Posted by dk1 View Post
    Thanks guys.
    assuming the temperature selectors are set to the same temp -
    and assuming the actuators are functioning properly -
    the most likely cause is a low charge of freon -
    connect a set of AC gauges - and report back with BOTH -
    the HIGH pressure reading - and LOW pressure reading -
    DO NOT BE TEMPTED TO JUST ADD SOME FREON -
    you could damage the system -
    and DON'T be tempted with one of those mickey-mouse "recharge kits" -
    with the el-cheapo gauge attached to a hose -
    dk1
    Sep 2010
    West Hollywood
    48
    64
    I forgot to mention I've had the system checked several times since the condensor was replaced and the charge is accurate. This is a problem that comes and goes since I've owned it, sometimes just working the temp from 60 to 90 a few times corrects it but other times not. I did notice a paper clip when I took it apart and it makes me think someone riged it previously but I can't see where it may have connected.
    69
    82,163
    Definitely an actuator or sticking door.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,564
    it's POSSIBLE the MIX - or BLEND door is sticky -
    give it a little shot of WD40 at the pivot points -
    and check around the edges of the flap for some loose foam -
    or some other obstruction -
    the other possibility - is a bad actuator -
    but that would usually set a code - or you would hear it clicking -
    dk1
    Sep 2010
    West Hollywood
    48
    64
    I will try that as I did remove the rest of the filthy cabin filter yesterday. I removed it 3 years ago but when I was under there I noticed more was in there I removed like 1 and a half more so it could be junk in there. How do I access the driver side? Do I remove the side panel by the accelerator?
    69
    82,163
    Yes. Remove that panel and then remove the 3 stacked interlocking filter elements.
    dk1
    Sep 2010
    West Hollywood
    48
    64
    Thanks I think were on to something just took it for a drive with all the filters removed and let me tell ya, it hasn't felt that nice in a long time. I will keep my fingers crossed just can't wait to put it all back together as I broke the valet switch lol but it should be here in 2 days.
  11. Remove Advertisements
