99 STS A/C not cooling Please advise... - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Like Tree3Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 STS A/C not cooling Please advise... in Past Cadillac Vehicle Discussion; I assumed the function of the valve would be obvious, and thought you just didn't realize there was one. The ...
  1. #16
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I assumed the function of the valve would be obvious, and thought you just didn't realize there was one. The valve is between the line and the sensor. When the sensor is in place, the valve is open, and the sensor can read the pressure. When the sensor is removed, the valve is closed, so the refrigerant doesn't leak out.
    basscatt and basscatt like this.
  2. #17
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    Re: 99 STS A/C not cooling Please advise...
    thank you for clearing that up for me Moist.
  3. #18
    68
    81,887
    Now THAT would make sense and make replacement easy, which makes me wonder why GM would do that.
  5. #19
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,349
  6. #20
    tenaculum is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS
    Apr 2013
    Knoxville, TN
    45
    5
    I am thinking this sensor may be out of my league... Any ideas on the inlet door? That seems to be something I could probably access under the dash somewhere. I know it has to be faulty because I can't even get fresh air in from the outside environment. It will blow, but very warm air comes out... If I could get that door opened I could perhaps allow outside air in and it wouldn't be so unbearable...
  7. #21
    cnslawn is offline Cadillac Owners Member
    Automobile(s): none
    May 2014
    None
    1
    you will have very little to NO freon loss when changing out pressure sensors they all have schrader valves under them to allow for easy changing without the need to evacuate the system every time you need to change one
  8. Remove Advertisements
