Possible cracked block/head, blown head gasket?
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, Possible cracked block/head, blown head gasket? in Past Cadillac Vehicle Discussion; I'm looking into buying a 1999 Eldorado, 124k miles, the interior is pretty good, the outside is great except the ...
    tierzu is offline Cadillac Owners Member
    Automobile(s): NONE
    Apr 2013
    5
    I'm looking into buying a 1999 Eldorado, 124k miles, the interior is pretty good, the outside is great except the rear driver side panel has some cracking to it, maybe the paint. The problem is the car has coolant mixed with the oil, and it's leaking the mix as well. The owner said someone told them it was a cracked block. I was curious if it could be something else? I've heard that head gaskets can leak externally, and usually when a block is leaking coolant it's just the water jacket that's cracked. It could even be a blown headgasket and a cracked block which combined produce the symptoms it has. I was curious for anyone else's thoughts on the matter, and if they've heard of one of these northstar engines both having coolant mixed with the oil and having the mixture leak out. The leak seems to be coming from the firewall side of the engine
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Re: Possible cracked block/head, blown head gasket?
    Northstars dont mix oil with colant on a blown HG. I'm thinking cracked block/or head. Run away
    Ranger is online now Cadillac Owners Member
    68
    82,066
    Cracked block and or heads are not very common and as mentioned, the Northstar almost never mixes coolant in the oil when a HG fails and they do not leak externally. Might be a ruptured oil cooler in the radiator side tank. If that's the case, I'd expect to see oil in the coolant as well.
    Automobile(s): NONE
    Apr 2013
    5
    I didn't get a chance to check the coolant reservoir while I was there but that'd be better than having to replace the headgaskets. I also didn't get a very good look underneath because the car wasn't on ramps or anything but it looked like it was leaking the oil/coolant mix down from the firewall side of the engine and dripping off of the oil pan. I checked the heater core hoses and it didn't look like there were any holes or cracks for it to spray onto the back of the engine.
    68
    82,066
    Are you seeing this oil/coolant mix on the dipstick?
    Automobile(s): NONE
    Apr 2013
    5
    There and the filler cap.
    68
    82,066
    You are seeing an oil/coolant mix on the tip of the dipstick when you pull it, not on the handle? When you say on the filler cap, you mean on the inside of the cap? Just want to be sure we are on the same frequency.
    Automobile(s): NONE
    Apr 2013
    5
    Yeah, on the tip of the dipstick and on the inside of the cap.
    68
    82,066
    Hmm, that doesn't sound good.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    99 car with coolant/oil issues? Hope ur only offering 700 or so. Depends on miles.
    Automobile(s): NONE
    Apr 2013
    5
    124k miles, the leather is cracking, no open rips or tears yet, missing stereo, cracks in the rear driver side exterior. Plus he wants $850 for it. I'd have been willing to drop the cradle and all that to change the head gaskets but having to replace the entire engine is something I don't have the time or resources to do. I'll probably pass because there are a few recently listed Cadillacs with 100k miles or less that are in much better condition for $1000-$1500. One wont start, one needs a catalytic converter, and the last they say needs a head gasket. Thanks for all the help and all the information.
  14. Remove Advertisements
