99 STS Starting disabled??
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 STS Starting disabled?? in Past Cadillac Vehicle Discussion; I currently have a 99 sts, and at random times in the morning when i start it up, it shakes ...
    mitchell122789 is offline Cadillac Owners Member
    Automobile(s): 99 Seville STS
    Apr 2013
    27
    6
    I currently have a 99 sts, and at random times in the morning when i start it up, it shakes kinda bad at idle, and i get a warning "Starting Disabled", then the car shuts off. I start it back up and it's just fine. Anyone know what would cause this?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,577
    Re: 99 STS Starting disabled??
    Welcome Aboard !!!
    Your car has its own built-in diagnostic code system. Study the proper year group/button push sequence up ^^^ in the sticky post just above - "How to pull codes". Write down any found codes and whether each is Current or History. Now go to http://www.obd-codes.com/trouble_codes/ and, using the main page as well as the links in the second paragraph, decipher all codes found. Write it all down and post it all here.
    Read all the stickys in this forum page - just above this post - as well as those in Engines; Northstar Performance. Go up ^^^ to the top black bar and study the entire Cadillac Technical Archive - there's info there that you need to know and that few people even bother to learn.
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    Well, at least yours starts and runs after, my 99 ESC gives me the same error message and just plain wont start.
    Which is why I've decided to part it out.
    Have you cleaned the pellet on your ignition key with a pencil eraser?
    I've heard that works.
    Apr 2013
    27
    6
    There are no codes, no CEL or anything.
    And i'll have to try that Tankboy, and thank you guys for the help!!!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If you're getting that message, there is a code.
    Apr 2013
    27
    6
    I don't know if it's a bug or what, but there are no codes. It simply, on startup, reads starting disabled then the car cuts off. Once I fire it back up, it acts completely fine.
    Buster28 is offline Cadillac Owners Member
    Automobile(s): 2000 ETC 18K miles, 1991 Allante 11K miles, 1996 ETC (sold)
    Sep 2010
    RI
    23
    On my 00 ETC the "Starting Disabled" message means the anti-theft circuit resistance value provided by the ignition key pellet is "incorrect" and can produce DTC B2710 when a zero (open circuit) resistance is measured. I am reasonably sure your 99 STS operates the same. This link discusses the problem : http://www.docstoc.com/docs/68098095...let-Resistance
    Accordingly, when you turn the Ignition Switch to the On position the fuel pump starts for a couple of seconds which pressurizes the the fuel rail. When you start the engine it runs on the fuel in the system but the fuel pump does not restart due to the DTC being set so the engine shuts down on fuel starvation. Apparently when you attempt a restart, the DTC B2710 clears because the correct resistance is present and pump restarts so the engine keeps running. Other related DTCs can invoke a 3 minute wait before a restart sequence can be initiated.
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you pull the codes through the DIC?
  11. Remove Advertisements
