Want to install magnaflows, which one is the muffler?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Want to install magnaflows, which one is the muffler? in Past Cadillac Vehicle Discussion; The '00-'04 series uses a 2 1/2" front flanged flex pipe-to-cat exhaust pipe, a section with O2 sensor boss, a ...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,539
    Re: Corsa exhaust or Magnaflow?
    The '00-'04 series uses a 2 1/2" front flanged flex pipe-to-cat exhaust pipe, a section with O2 sensor boss, a smallish labyrinth resonator/muffler, a 2 1/8 - to - 2 1/4 roller bent tailpipe to a 2 1/8 - 2 Y into huge, heavy labyrinth stamped mufflers with 1 3/4 pipes to phony dual tips. All roller bent and stamped welded.
    The CORSA is also all s/s, but 1/4 to 1/2 larger everywhere and mandrel bent. Begins just behind the OEM honeycomb cat. The resonator/muffler and mufflers are straight through units with calculated resonance holes burned from the pipe into the main bodies. NO packing. If you put the system together on your garage floor, you can see a flashlight beam through the whole thing. Its a lot lighter, too. Uses all the original rubber cookie hangers. Very quiet on the highway with a low rumble at idle. Will truly wake the dead on a 1-2 WOT run, and is purrrrfect coming down the tach in 2. Guaranteed for life. Pricey and just great. Love it. Use a lift, be careful measuring, and probably need 2 small s/s hose clamps on the rear muffler rods to maintain center. www.corsaperformance.com .
    Don't try to outguess CORSA: use the anti-seize and a torque wrench and you won't have any leaks. Get creative and you'll have a mess.
    Feb 2006
    55,539
    WolfFang is offline Cadillac Owners Member
    Automobile(s): 2001 SLS
    Apr 2013
    23
    32
    Hey. I have a 2001 Seville SLS. I want to install magnaflow mufflers on the car. Something with a nice mellow rumble at idle. I'm confused on where the actual muffler is however. Is it the one after the cat converter, or the two rear ones? Should I get two magnaflows and put them on the rear and leave the front one alone, or just one near the cat converter and leave the two rear ones alone. I'm confused.
  5. #4
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Srsly?
  6. #5
    Apr 2013
    23
    32
    Re: Want to install magnaflows, which one is the muffler?
    Yah srsly. I thought the rear two were mufflers and the one up front was a resonator. I've heard otherwise though.
  7. #6
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    It goes:
    Exhaust manifold>y-pipe>catalytic converter>split>mufflers>tips
  8. #7
    Apr 2013
    23
    32
    This is what I was reading that confused me
  9. #8
    Feb 2006
    55,539
    That does not appear to be my post or even my writing style - I've done CORSA exhausts on 4 Sevilles now and I have a very clear picture of what's what - as in: Flex joint, cat, resonator, Y, 2 mufflers, 2 tips.
    Maybe it's in an old thread about the setup on a different car ???? Beats me. (If it IS my post, it's wrong !)
    Here's my car - you can just see the bottom of the resonator toward the front of the system - the shiny thingy in front of the crossbar hanger.
  10. #9
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    any 19yr old who wants to buy a caddy deserves some slack. he could be putting a fart can on a honda. but he is not.
    vincentm and vincentm like this.
  11. #10
    Feb 2006
    55,539
    Wut ???
    What slack ??? He's asking about the order of things in the exhaust system ................. so he can go to Magnaflows ........... the post he found is from 2007 and has nothing to do with "slack" !
    I'm trying to find the thread it came from because if it refers to his SLS it's wrong-o ! His post is a screen shot, not a bump, so it will take time to find the original old thread.
    EDIT: I've found 4 threads from 2006 - 2007, talking about CORSA installs - and the info from all members (me included) is correct on the order of system parts - When I find that ^^^ one I'll edit it if necessary.
  12. #11
    Aug 2007
    mpls mn
    2,528
    Many cars have muffs and resonators. I have seen the rearmost can referred too as a resonator on some cars. On some SUVs they call them spark arresters. Friends navigator has several sequential similar sized cans on his rig
  13. #12
    Apr 2013
    23
    32
    Quote Originally Posted by Submariner409 View Post
    this is the post I was reading sub.
    http://www.cadillacforums.com/forums...ill-quiet.html
  14. #13
    Feb 2006
    55,539
    Thanks - Yep, my bad ........... and I said that AFTER I had done my own CORSA !!! Check the date on the pic - from my old Kodak point & shoot antique digital.
    (They say the mind is the second thing to go ..................)
  15. #14
    68
    81,744
    Oddly enough, the mufflers (33 & 37) and resonator (26) are shown, but not listed in the part detail.
    http://www.gmpartsgiant.com/Page_Pro...033&SortKey=66
  16. #15
    Feb 2006
    55,539
    Wasn't that phony dual system available from GM ONLY as a complete piece - flange to tips ?? (Which is why the thing cost $1200++ ?).......... no clamps in there - it was all welded.
  17. Remove Advertisements
