Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: '97 Eldorado Rear End Squeaking Like Crazy Down the Road
    NTL1991's Avatar
    NTL1991 is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Eldorado - Polo Green Metallic
    Feb 2009
    Rhode Island
    96
    My Eldorado has been squeaking like crazy down the road. Every bump, pothole, or irregularity makes the rear end squeak. It sounds like it's mainly coming from the rear right, but could be both sides. It also happens when you bounce the rear end of the car. I took a video to demonstrate.
    Anyone have the same squeak?
    Thanks,
    Nick
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Re: '97 Eldorado Rear End Squeaking Like Crazy Down the Road
    The most common cause of this is the ball joints in the knuckle.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    i have the same problem, so i changed my knuckle bushing, it helped the car feel more stable and it lessened the noise by 70 percent but its still somewhat there, im convinced its the control arm bushings now
  5. #4
    2kflhr's Avatar
    2kflhr is online now Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Dec 2004
    Mooresville, NC
    58
    905
    Usually the control arm bushing and/or sway bar bushings
  6. #5
    NTL1991's Avatar
    Feb 2009
    Rhode Island
    96
    I replaced the rear air shocks about 250 miles ago. The squeaking has been there quite a bit before that, but dropping the control arms fully down to get the shocks in might have upset the bushings as well. The car was sagging a bit in the rear for about a year before I put the new rear air shocks in, I'm sure that didn't help the bushings either. Last time I checked for play I didn't have a bit anywhere. I've got to check that again and try to spray some white lithium grease in the bushings to see if it changes the sound. The car seems to drive fine with no shimmy or anything like that. I haven't driven another Eldorado so I'm not sure what to compare it with. I'll have to visually check the bushings out. Once I remove the knuckles, can the old bushings be pressed out and the new pressed in? Could a bench vice press the old out (maybe with heat?) like we would with u-joints back in the day, or will I have to drop them off at a shop to use a hydraulic press?
    I just spent the day buffing the car out with some compound and polish, then waxing it, but as nice as the car looks, it squeaks like a beat up 25 year old Honda...
    Thanks,
    Nick
  7. #6
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by NTL1991 View Post
    A ball joint press works the best. Shooting grease won't quiet them. they are actually a cross-axis ball joint, and you'll never actually grease the joint from the outside. The best you can do to diagnose them is having someone bounce the car while you feel around for vibration from the squeaking and creaking. Keep in mind that GM doesn't provide replacements - they'll only sell you the whole knuckle for a ridiculous price. The joints are available aftermarket.
  8. #7
    NTL1991's Avatar
    Feb 2009
    Rhode Island
    96
    Okay. Sounds like I'll be picking a ball joint press up. I'm seeing many polyurethane bushing kits on line, but I also see Dorman bushings on RockAuto. Would these OE style bushings be the best bet?
    Thanks,
    Nick
  9. #8
    turbol15 is offline Cadillac Owners Enthusiast
    Automobile(s): 97 eldo,2011 cts-v
    May 2010
    New york
    673
    I used dorman and poly all around. the squeak may also be the springs in the trunk. I still have same squeak
  10. #9
    Oct 2004
    Oak Creek, WI
    5,607
    OE is the best in this case
  11. #10
    2kflhr's Avatar
    Dec 2004
    Mooresville, NC
    58
    905
    Yep, poly is for true muscle cars, unless you're willing to live with vibrations they create because they are so much firmer. I put a poly trans mount on my SS Camaro when I had to replace it. I drove it about 50 miles came home and took it out and went back with OEM style.
  12. #11
    Oct 2004
    Oak Creek, WI
    5,607
    The cheap poly replacements offered are the wrong type of bushing for this application. Again, these are actual ball joints in this case. Replacing them with rubber or poly bushings will create alignment, handling, and durability issues.
  13. #12
    NTL1991's Avatar
    Feb 2009
    Rhode Island
    96
    Great info, thanks. Looks like I'll be ordering a set of the Dorman bushings once I take a look at the originals. I'll probably order a set of sway bar end links for the rear as well, while I'm back there.
    Thanks,
    Nick
  14. #13
    eldoradoin's Avatar
    eldoradoin is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Eldorado/Slate (R.I.P.) 1997 STS, 2002 Eldorado ETC
    Oct 2007
    Virginia Beach
    51
    286
    Are my eyes deceiving me, or is that wheel showing a hellacious negative camber?
    edit: 1st picture
  15. #14
    NTL1991's Avatar
    Feb 2009
    Rhode Island
    96
    Nope, it's the combination of holding the camera sideways, and the fact that the car was parked on a relatively steep incline (driver's side high, passenger's side low) The video was filmed from the rear passenger's side of the car, and it makes it look like the camber is way off. I do need a rear alignment, though, but when I went they couldn't break the bolts free, so I had them do the front end only.
    Nick
  16. #15
    Oct 2004
    Oak Creek, WI
    5,607
    The front wheels actually rely on the rear wheels when it comes to alignment - that said, on a car with adjustable rear, it's impossible to CORRECTLY align the front without doing the rear first... They must be done together in the same session
  • You may not post replies
