Eldorado Door Wind Noise - Page 2
Results 16 to 30 of 31
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Eldorado Door Wind Noise in Past Cadillac Vehicle Discussion; Thank you.....
  1. #16
    jammgm's Avatar
    jammgm is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS Luxury, 1998 Eldorado ETC Crimson Pearl
    Mar 2011
    West Haven, CT
    54
    352
    Re: Eldorado Door Wind Noise
    Thank you..
  2. #17
    txtaz is offline Cadillac Owners Fanatic
    Automobile(s): 72,92,02 Eldorado
    Jan 2013
    55
    185
    Quote Originally Posted by jammgm View Post
    Taz, what did you do to align the new gasket. When looking at the mirror and door gaskets, I cant tell where the problem is. Any suggestions would be appreciated.
    Good info on the door gasget adjustment.
    The mirror gasket has the 3 bolts holding the mirror on and 3 screws. One screw goes through a metal tab on the gasket. Loosen these and align the gasket to make a smooth transition on the forward glass egde. Silicone and heat on the door gasket where they meet will help seal it. Or bring it to Texas in a month or so and let it sit in the 100 degree heat for an afternoon.
    Taz
  3. #18
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    54
    352
    Quote Originally Posted by txtaz View Post
    Taz
    Thanks for the info Taz.
    As for applying heat, I'll use a heat gun or dryer vs coming to Texas. Not a fan of real hot weather from living in New England.
  5. #19
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    54
    352
    Taz
    Ranger, Taz, I just received my replacement gasket from Chris (Rippy) and getting ready to replace it. Very fast service
    Before removing all the bolts, how does the plastic cover come off? Does it pop off or lift up?
    Thanks, Jim
    Thanks, Jim
    i.e. I'm referring to item #5 from the parts diagram.
  6. #20
    68
    81,916
    Not that familiar with the Eldo.
  7. #21
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    On mine, it came off with the door panel...
    be SURE to remove the phillips head screw under the window switch BEFORE you begin to lift the door panel upwards.
  8. #22
    68
    81,916
    Quote Originally Posted by Tankboy40 View Post
    That's what I am familiar with on the Deville. Kind of thought the Eldo would be the same.
  9. #23
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    54
    352
    Hmm.. I'm starting to remember that now having taken them off several times. Must have been a case of CRS.
    Thanks guys..
    Taz
    Taz, when you apply the heat to the door gasket, do you apply it to soften it than close the door on it to have it form the seal to the mirror gasket? Just trying to understand how this is done to improve the sealing between the 2.
  10. #24
    Jan 2013
    55
    185
    If you are asking about the interior plastic vent on the door panel which covers the mirror bolts and such, you need to pull the door panel. That piece is hot glued and nutted to the door panel. Be carefull not to break the tabs on the bottom of the panel. Lift up first, then rotate way from the door. Even if you are carefull, the tabs may break due to age and the sticky foan they put on them. It happened to me and I've had Eldo door panel off dozens of time.
    Yes, Mine had been mis-aligned for 10 years. After aligning there was a gap where the mirror gasket used to meet up the door gasket so I heated up the door gasket (where the mirror gasket met) then closed the door and let it cool. I've done 3 cycles so far and it's gotten much better. Mind you, it was cold (30's) when I was doing this. If I had more patience, I would have waited till the heat came and it would have re-moulded itself to the new shape faster.
    Taz
  11. #25
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    54
    352
    Taz
    So what exactly was out of alignment on the mirror gasket? When looking at the new one, it doesn't look like it would.move much. Just curious...
  12. #26
    Jan 2013
    55
    185
    The window was out of alignment. The front edge was too high and kept ripping the mirror gasket. Plus it was forward about 1/4".
    Taz
  13. #27
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    54
    352
    Taz
    Got it.. thx!
  14. #28
    jammgm's Avatar
    Mar 2011
    West Haven, CT
    54
    352
    Taz,
    I replaced the mirror gasket (Thanks Chris!) as per your instructions which fixed some of the noise but still had it coming from the front part of the door. I siliconed the door seal on the car but that didnt help. I found the part of the gasket on the car that meets up with the mirror gasket wasn't sticking out enough. So I got some weather stripping from Lowes/HD with the adhesive backing and placed a couple pieces stacked up behind the seal to push it out more. The drivers side is now completely quiet. Just have to do the passenger side and should be good to go. Thanks again for your help.
    Jim
  15. #29
    99 caddy eldo esc is offline Cadillac Owners Member
    Automobile(s): 1999 eldorado
    Nov 2012
    La Place, Il.
    53
    1
    Mine had a rip in it, I took needle & thread and sewed it. Probally will not last long but should get me through till I get my p420 code taken care of first. The wind noise was just driving me nuckin futs. I'll order a new gasket next. Thought this might help someone else in a similar situation money wise. I really hate not doing things the right way first but sometimes you got to do what you can get by with for now.
  16. #30
    heavenbound1 is offline Cadillac Owners Member
    Automobile(s): 1996 eldorado
    May 2013
    56
    10
    I guess a lot of these have that air leakage in the window. mine is a 1996 Eldorado. I often have to lowere and raise the window from time to time to get the air noise to stop.
  17. Remove Advertisements
