Disable Check Brakes DIC warning?
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Ranger
  • 2 Post By Submariner409
Cadillac Seville / Cadillac Eldorado Forum Discussion, Disable Check Brakes DIC warning? in Past Cadillac Vehicle Discussion; I recently installed Satisfied pads and the space for the sensor was a lot bigger than the one on the ...
    carmaster is offline Cadillac Owners Fanatic
    Automobile(s): 02 Seville STS
    May 2005
    Providence, RI
    31
    314
    I recently installed Satisfied pads and the space for the sensor was a lot bigger than the one on the previous pads. So I zip tied it out of the way. Is there a resistor or something even easier to do to get the message to go away? Besides hitting the clear button every time I get in the car.
    69
    82,266
    Re: Disable Check Brakes DIC warning?
    If you connected the sensors, the message should go away. If you still have the old worn sensor on it, just connect the two wires.
    curtc and curtc like this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    The 4 sensors form a series circuit - any one sensor wears open (breaks the circuit) and the message shows.
    carmaster and carmaster like this.
