Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Need Help With Passive Struts and Shocks
    EROD316's Avatar
    EROD316 is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac STS
    Jan 2007
    QUEENS, NY
    46
    10
    Hi all, I need someone help about passive struts and shocks.
    I have a 2000 Cadillac Seville STS, and I cannot find the correct part numbers for passive shocks and struts and also cannot make up my mind which ones to get i prefer Monroe. I can get a set of OEM rear shocks w/o electronic level control brand new for $90 a pair will these work. Which passive struts can i get for the front that might have the spring installed already.
    I do have the FE3 and F45 options
    Also what size resisitor from radio shack should i purchase to bypass the suspension system?
    PLEASE HELP ME!!!!!!!
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    What's wrong with ur shocks? Do u have a ride height issue due to airline leaks or bad compressor or shock body seepage or are you getting service suspension messages or did a shop just say u need new shocks?
    EROD316's Avatar
    Jan 2007
    QUEENS, NY
    46
    10
    Re: Need Help With Passive Struts and Shocks
    I purchased the vehicle from an elderly man that unfortunately cannot drive no longer, after checking the vehicle the vehicles needs struts and shocks they rattle in the front and back, the vehicle bottoms out going over a bump front and back. The vehicles has 177,709 miles and has the orginal struts and shocks. The compressor works fine, no service suspension messages. I do have some shock body leakage due to rott on the boot.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Monroe struts - 71684
    Monroe shocks - MA822
    Monroe does make a Quick-Strut assembly, but the springs are softer than your stock springs.
    Check on RockAuto, Amazon, and google the part numbers for the best price.
    Resistors - 1/2 watt, 4.7K ohm. $1.19 for a 5 pack at RadioShack.
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    MONROE is definitely the way to go -
    and MC supplied the correct part numbers -
    front strut #71684 - the best price today is $62.25 each with free shipping -
    http://www.partsgeek.com/jzhsgdr-cad...bly.html?fp=pp
    rear shocks MA822 - the best price today is $58.60 - for BOTH - with free shipping -
    http://www.partsgeek.com/gbproducts/...FY1aMgoddwMAIA
    BONUS -
    Monroe has a rebate going on right now -
    if you purchase 2 Monroe SensaTrack struts - and a set of MaxAir shocks -
    you get a $60 pre-paid visa card -
    http://www.monroe.com/assets/downloa...ate_US_WEB.pdf
  7. #6
    joseville is offline Cadillac Owners Member
    Automobile(s): 93 seville 4.9
    May 2011
    wisconsin
    32
    83
    How do I find the correct part numbers for my car. I have a 93 seville with a 4.9.
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Quote Originally Posted by joseville View Post
    for the correct parts available for your car -
    go to http://monroe.com/
    then do a search of those part numbers -
    rockauto.com has had the best prices lately -
    partsgeek.com and amazon.com are also good sources -
  9. #8
    May 2011
    wisconsin
    32
    83
    I have done that on a bunch of different sites. There is always more then one.
    On my drivers side rear shock, the nut on the top of the shock broke thru the shock mount plate. I went to auto zone and bought the rear shock mount that had listed for my car and it ended up being the wrong size. Even the shocks they listed didn't match up right. They looked right but didn't fit. All that work to get the shock out (outside while it was snowing) and then it didn't fit. It was such a pain in the ass too. Trying to figure out how to get the nut to break loose. Either the shock wanted to twist or when using a big pry bar to hold it from doing so the piston rod ( i think that's what its called ).
    The price for Cadillac parts are ridiculous!!! To replace the rear shocks it will cost more then I paid for the car in 09. And that's with buying aftermarket parts
  10. #9
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    according to the Monroe site I supplied above -
    i used your specific information -
    93 Seville with the 4.9 motor -
    front struts -
    71854 - $63.25 each - with free shipping -
    http://www.partsgeek.com/8svw6h3-bui...bly.html?fp=pp
    the rear shocks can be a little tricky -
    there were two styles used around that time -
    MOST used the Monroe 71801 - $66.25 each - with free shipping -
    http://www.partsgeek.com/95w6z82-cad...bly.html?fp=pp
    OR it could be the Monroe 40046 - $105.70 - each - with free shipping -
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    look at the bottom mount - which style do you have?
  11. #10
    Aug 2007
    mpls mn
    2,527
    car is a 2000. why are parts being listed for a 93? do they use same rear shocks?
  12. #11
    Sep 2007
    Wilmington, NC
    13,969
    shocks don't really rattle
    maybe you just need sway bar links or something
  13. #12
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Quote Originally Posted by stoveguyy View Post
    no - the thread got sidetracked - see post #6 -
  14. #13
    EROD316's Avatar
    Jan 2007
    QUEENS, NY
    46
    10
    Hi
    First thank you very much for all your help, I have installed the struts and shocks over the weekend in my 2000 cadillac STS. For all that was skeptacle about a different ride in there STS they are mistaken. My Caddy rides like a dream smooth, actually better than before. The bypass resistor worked out great. Being a master technician for cadillac for 15 years you never stop learning something new. Thank you again for all your help.
  15. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Quote Originally Posted by EROD316 View Post
    Hi
    thanks for the update -
    glad you are happy with the Monroes -
    but I knew you would be -
  16. #15
    gino9's Avatar
    gino9 is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado 4.5 88' & STS 4.6 N* 01'
    Sep 2009
    Oxford,UK
    34
    165
    Ok I need change front struts(front car bump on bottom bumper)what resistor is for?When I will change my old oem for passive strut I need buy resistor?
    Did you try repair or check reason why they not work propely?
  • You may not post replies
