Compass mirror - 2003 Seville wiring details
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, Compass mirror - 2003 Seville wiring details in Past Cadillac Vehicle Discussion; hey guys this is my first post here. i just pulled the rear veiw mirror out of a 2003 seville ...
    matthew13sanderson is offline Cadillac Owners Member
    Automobile(s): none
    Feb 2013
    23
    4
    hey guys this is my first post here. i just pulled the rear veiw mirror out of a 2003 seville sts today. main reason i want it is to use the compass, but any direction or info on how i could get all the features working would be great. from the reading ive done so far, im lead to beleive that the box that i have attached to it is the compass. it has a white, yellow, black, orange and green wire going into it, then back into the mirror. it had another box somewhat attached to it, and i typed the number that was on it, into google and found out it was some sort of wiper sensor, which i have no interest in using so i took it off. and im pretty sure the little circle peice is for the onstar system becuase of the fact it says to wire to speakers on it.
    basically what i want to know is if im correct about what ive said so far, and how i would go about wiring the compass up so it works. im also curious about the tempature sensor and it its built into the mirror, or if i have to go back to the same car and get the sensor out of it. any help, advice or pictures on the subject would be great!
    all the wires that clip into the back of the mirror
    this is what i think is the compass. all the wires go from the back of the mirror to this
    inside of "the compass"
    pretty sure this is for the onstar
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If the mirror is from an '03, the mirror should be all 1 piece, other than the RainSense sensor. The compass is part of the mirror, there is nothing external.
    The ambient temp sensor is attached to the hood latch assembly, but the mirror does not display the temperature.
    There are after market compass mirrors available. You wouldn't have to deal with the extra wires and buttons, and some have map lights.
    Edit: Now that I see the pictures, that does look like it's from an '01-'03, so that's the wiring diagram you'll need. Yes, the round thing is the OnStar mic.
    You don't have to do any wiring for the compass to work, other than supply power to the mirror.
    scott f's Avatar
    scott f is offline Cadillac Owners Fanatic
    Automobile(s): 2002 STS/ 1994 STS
    Oct 2010
    Oshawa, Ont. Canada
    229
    Re: compass mirror.
    Automobile(s): none
    Feb 2013
    23
    4
    Re: compass mirror.
    alright thanks for the help so far! so the compass is already in the mirror ready to go, which set of wires would be the power & ground? also, if the compass components are in the mirror, what is the black box that i though was the compass?
    another thing, when i look at the digital part of the mirror in the right light, it looks to me like it says F and C with the degrees symbol beside it.
    Sep 2003
    Metro ATL
    4,854
    Re: compass mirror.
    Quote Originally Posted by matthew13sanderson View Post
    ....another thing, when i look at the digital part of the mirror in the right light, it looks to me like it says F and C with the degrees symbol beside it.
    The mirror has display capabilities that GM/Cadillac did not use. For example, the compass can be displayed as a conventional 3 digit "heading" figure instead of the GM default of one of 8 heading approximations (N, NE, E, etc).
    If you can identify the manufacturer of the mirror, they might be willing to share internal specifications and external wiring requirements. But don't count on it!
    Automobile(s): none
    Feb 2013
    23
    4
    Re: compass mirror.
    with a little more research i found ground and the 12v source. i hooked them up to a battery and the compass works! the mirror dimmer would also work so im assuming that it is one of the options that is in the mirror itself too?
    im still curious about the black box though.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,179
    Re: compass mirror.
    If the squarish black box was separate but next to the mirror - and attached to the windshield by clear adhesive - it's the RainSense windshield wiper sensor module. Maybe all the wiring bundles into/through the mirror umbilical.
    JimD, Is there a magic button push sequence that will display heading in digits vs. the useless cardinal compass points ?
    Sep 2003
    Metro ATL
    4,854
    Re: compass mirror.
    Quote Originally Posted by Submariner409 View Post
    Not that I know about but I did not pursue the issue since a useful heading display would have confused the 'other' driver.
    You can see more of the display options if you focus on the mirror during the KEY ON power up test sequence.
    Ranger is online now Cadillac Owners Member
    68
    82,048
    Re: Compass mirror - 2003 Seville wiring details
    Heading would be cool.
    eldorado_97's Avatar
    eldorado_97 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 STS, W/Nav
    Feb 2007
    Baldwin, Wisconsin
    27
    562
    oh great now you guys got me all curious lol we should figure that out
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    Here are the schematics, location view, calibration procedure, and connector pin out for the 2003 Seville inside rear view mirror. These are from the 2003 Cadillac Seville Factory Service Manual (FSM):
    http://www.gyan.com/cadillacforums/2...dOperation.pdf
    http://www.gyan.com/cadillacforums/2...orLocation.pdf
    http://www.gyan.com/cadillacforums/2...Schematic1.pdf
    http://www.gyan.com/cadillacforums/2...rrorWiring.pdf
    http://www.gyan.com/cadillacforums/2...alibration.pdf
    Feb 2006
    56,179
    This thread will be copied as a sticky in Cadillac Tech Tips. Thanks to all for the research.
  15. Remove Advertisements
