Plug wires - too obsessive
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Plug wires - too obsessive in Past Cadillac Vehicle Discussion; I have the original plug wires on the '99 STS. That means they are 13 years old now. Plugs were ...
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    I have the original plug wires on the '99 STS. That means they are 13 years old now. Plugs were replaced at 85k. Would you replace plugs wires based on age? I'm not noticing a miss or anything, just think it might restore a little efficiency that might be lost over time.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Plug wires - too obsessive
    plugs and wires should have been done at 100,000 miles
    so you replaced the plugs a bit early and are late on the wires
    i would replace them just out of concern for their age on top of the over-mileage issue
    EcSTSatic's Avatar
    Dec 2004
    Wichita, KS
    5,212
    Thanks Chris. I usually compare OEM scheduled maintenance with Captain Barbossa's description of the Pirates Code, more like guidelines.
    Some plug wire manufacturers offer lifetime warranties. If that were true, there would be no replacement interval.
    I usually try to heed my cars' symptoms before I act, but some things sneak up on you.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    They say
    L7SQ is offline Cadillac Owners Member
    Automobile(s): '97 Eldorado ETC
    Mar 2011
    Inland Empire, Ca
    28
    89
    Get them from rockauto.com, I got my AC/Delco plugs and wires for ~$100
    Sep 2007
    Wilmington, NC
    13,986
    There's two sets of ACDelco wires ... the cheaper set is made to compete with the aftermarket brands and isn't quite as good as the OEM set but i'd say they're still much better than other aftermarket wire sets
    the one visible difference that the OEM wire set has is that the wires are numbered (i don't think the cheaper set has the numbering)
    there are possibly other differences like materials used and quality control
  9. Remove Advertisements
