Low oil causing ses light to flash and run like crap
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, Low oil causing ses light to flash and run like crap in Past Cadillac Vehicle Discussion; ...
    one bad sts's Avatar
    one bad sts is offline Cadillac Owners Member
    Automobile(s): 2003 Seville STS 1991 Seville 1992 Coupe Deville
    Aug 2011
    Cleveland, Ohio
    32
    23
    AngryLow oil causing ses light to flash and run like crap
    Okay my educated cadillac friends i have been having some issues with my 2003 seville sts long story short the ses light has been flashing pulling a po300 code random misfire,done some things eveyone has recomeded i have done since :coil pack,plugs fuel filter,mass air flow censor,serpentine belt…ran out of options now the cadillac dealer is saying it was low on oil(i changed 1400 miles ago ) an added a qaurt saying i only had 2 qaurts of oil when he drained it please someone make sense of this ???thanks
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    Re: Low oil causing ses light to flash and run like crap
    It takes about 7 quarts, so if you had only 2 quarts left, then you would have been 5 quarts low. If you lost 5 quarts of oil in 1400 miles, then there must've been puddles under the car or a huge amount of smoke coming from the exhaust.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Low oil has nothing to do with a misfire.
    Quote Originally Posted by one bad sts
    The flashing SES light indicates a severe misfire. Do you have any other codes?
    Were these parts bad, or are you just throwing money at it? What kind of plugs were installed?
    Wait, WHAT???
    The dealer added 1 quart of oil to an engine that they drained 2 quarts out of? That leaves you 6.5 quarts low.....?
    How did the engine end up with only 2 quarts left in the first place? Don't you check it? Didn't you get a check oil level message?
    Aug 2011
    Cleveland, Ohio
    32
    23
    I checked it less then 2 weeks ago i put 7.5 in it 1400 miles ago and added one full quart no one drop of oil,most of the parts replaced were still cover under the warranty i have left, the plugs were replaced with factory gm plugs...the dealer was changing the oil because they said nothing was on the stick when they were draining it is when they only saw 2 quarts come out?? And i have never got the message besides once when i fisrt bought it 2 1/2 years ago never since then. I alsways check fluids
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Quote Originally Posted by 98cadillac View Post
    Did this ever get answered by the OP? Oil fouled plugs could cause a misfire. Did the dealer say anything when they were replaced? This story is hard to follow.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by EcSTSatic View Post
    You could say that again.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,374
    P0300 is a generic misfire code -
    our on-board code readers will not display WHICH cylinder/cylinders is/are misfiring -
    only that there IS a misfire -
    take the car to any large auto parts store - they will check your codes for free -
    P0301 is a misfire in cylinder #1 - P0302 is cylinder #2 - P0303 is #3 - etc -
    once you discover WHICH cylinder is misfiring - diagnosis becomes much easier -
    68
    81,928
    Quote Originally Posted by one bad sts View Post
    Numbers just don't match up. I'd bet that "2 qts" is someones exaggerated guess.
    And this pretty much proves it.
    P.S.
    Low oil level will not cause it to "run like crap" or have any affect on how it runs at all.
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Plugs, fuel filter, serpentine belt and oil change normal maintenance no harm done. Coil pack and mass air flow sensor another story.
    Flashing ses light dont drive car.
    As basscatt advised get codes.
    Runs like crap very vague. Mike
  12. Remove Advertisements
