HID Kit Wattage
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, HID Kit Wattage in Past Cadillac Vehicle Discussion; My friend has a 2001 Seville SLS with projectors but they have halogen bulbs in them. He wants to upgrade ...
    lsfanatic is offline Cadillac Owners Member
    Jan 2013
    56
    HID Kit Wattage
    My friend has a 2001 Seville SLS with projectors but they have halogen bulbs in them. He wants to upgrade to HIDs but what wattage would be best? I know 55w is brighter but I wasn't sure if that would be too hot for the factory headlight housing?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    It won't be too hot, but one train of thought is that the extra light being produced is offset by the fact that the extra bright light being reflected back at you from the road and objects in front of you, has a negative effect on your night vision.
    Also, bulb life will be reduced ~20%.
    Go with a high quality kit, such as the ones offered by www.theretrofitsource.com.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,846
    Re: HID Kit Wattage
    Quote Originally Posted by lsfanatic View Post
    I totally agree with MC -
    get a high quality 35w set -
    keep the bulbs in the 4100K to 4600K range for best light -
    5000K start turning blue -
    6000K are blue - and deliver LESS useable light on the road -
    what ever you do - DON'T let your friend get the el-cheapo
    $29.95 ebay specials - THEY ARE PURE GARBAGE -
    Sep 2010
    East Boston MA.
    29
    26,323
    5,000,K is regarded as pure white. 6,000K+ is getting blue.
    The range that basscatt posted is white with a slight yellow tinge (4,300K was stock with the factory HID option), is generally brighter, but there are 35 watt, 5,000K bulbs that put out more light.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: HID Kit Wattage
    Stick with whats been said above. 4300k is OEM and will produce the closest thing to natural sunlight.
    35w will do just fine, and be aware....You might need to reverse the polarity on the connection to the OEM system, I know I had to when I installed the HIDs in my old Seville. Through me for a loop for about 60s until I did a little Google'ing...
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,846
    Re: HID Kit Wattage
    oh - one moe thing -
    there is a special wiring harness available for around $10 - get it -
    Jan 2013
    56
    Re: HID Kit Wattage
    ok thanks for the feedback. I had heard about the reversed polarity and dealt with it on my silverado. so a 5000k 35w kit is best? I have used ddm tuning's kit before and it has worked well
    Sep 2010
    East Boston MA.
    29
    26,323
    Color temp is your choice, but I'd recommend staying between 4,000K and 6,000K for the best lighting, and to stay legal.
    Sep 2003
    Metro ATL
    4,854
    Re: HID Kit Wattage
    My friend has a 2001 Seville SLS with projectors but they have halogen bulbs in them. He wants to upgrade to HIDs....
    Wattage is not the (burning) issue. Be sure your friend knows his 2001 is on the bubble for the first year that Cadillac offered factory optional HID low beam bulbs in a Seville.
    The critical factor is -- IF the car left the factory with halogen bulbs, the LOW beams "might" be turned OFF when HIGH beams are selected. Which will result in a one-three second period of darkness when he selects LOW beams again. Not a desireable situation at 60 MPH on a dark and stormy night.
    Easy enough to test before he buys the parts.
    And there is a simple/easy mod to keep the LOW beams ON when HIGH beams are selected.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    Quote Originally Posted by JimD
    I installed aftermarket HIDs in my 2001, lows stayed on when high beams were engaged, no modification necessary.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,123
    Re: HID Kit Wattage
    Quote Originally Posted by curtc View Post
    Same for 2002 (Seville)
  14. Remove Advertisements
