2001 STS Power Steering Leaking?
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 STS Power Steering Leaking? in Past Cadillac Vehicle Discussion; Hi i see a clear oil dripping down when I Park the Car. If it is a Power Steering Problem ...
    PeterS is offline Cadillac Owners Member
    Automobile(s): 2001 (Seville) STS
    Feb 2008
    Staten Island,Ny 10309
    58
    81
    Hi
    If it is a Power Steering Problem What do you think it would be to replace it?
    Thank You!Pete
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,358
    Re: 2001 STS Power Steering Leaking?
    Quote Originally Posted by PeterS View Post
    Hi
    Thank You!Pete
    you need to find out WHAT is leaking
    before you can ask HOW MUCH -
    could be pump - pressure hose - return hose - the rack itself -
    OR just a loose fitting -
    ben.gators is offline Cadillac Owners Master
    Automobile(s): '14 ATS Premium with 3 pedals | Past: '13 ATS Performance & '99 Seville STS
    Aug 2009
    somewhere good!
    5,179
    As basscatt said, try to locate the exact leak point. In our cars, the most common leak point in power steering system is high pressure line, and the part cost is less than $100, and this is a fairly simple DIY project. There are a few nice write-ups too. But again, try to find what is leaking first.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    This is all assuming that it's power steering fluid. Clear oil?
    What area is the leak in?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,358
    ya - the only other clear fluid is brake fluid -
    but if the OP sees it dripping in the ground -
    I would expect the brake warning light -
    or check brake fluid message on the DIC
    Feb 2008
    58
    81
    Hi
    Thank You All For Your Help. It is a Very Good Start. I will Have to have it Checked out.
  9. Remove Advertisements
