replacing a 1998 eldorado oem catalytic converter with a 2000 eldorado oem cat?
Results 1 to 5 of 5
Like Tree2Likes
  • 4 Post By Mafiaman111
Cadillac Seville / Cadillac Eldorado Forum Discussion, replacing a 1998 eldorado oem catalytic converter with a 2000 eldorado oem cat? in Past Cadillac Vehicle Discussion; got a po420 code..so im n the market for new o2 sensors & a cat replcment but the 98 & ...
    DrCellycel is offline Cadillac Owners Member
    Automobile(s): 1998 Convertible Eldorado ETC
    Dec 2012
    47
    Lightbulbreplacing a 1998 eldorado oem catalytic converter with a 2000 eldorado oem cat?
    got a po420 code..so im n the market for new o2 sensors & a cat replcment but the 98 & 99 oem catalytic converters r discontinued from the dealer but a 2000 oem
    eldorado cat is still avilable for 1200$ from the dealer..soo i asked the dealer would it fit?..sooo the dealer says it will fit but recommended against it ...citing potiential problems codes etc but he wasnt really specific & he was reluctant to go further n
    detail..im leaning towards gettn the 2000 eldorado oem cat to go on my 98
    eldorado in order to aviod buying aftermarket mess..sooo hey wat u think? advice would greatly appreciated guys!!!!
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    Re: replacing a 1998 eldorado oem catalytic converter with a 2000 eldorado oem cat?
    Sometimes the code sets due to the O2 sensors readings being out of range, which does not mean you need a new converter or sensors....
    Have you looked/listened for vacuum leaks?
    A simple vacuum leak can cause that code, the O2 sensors being out of range and (if left for too long) damage to the Cat.
    Just my $0.02
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    I put a walker cat converter on my 98 eldo and the p0420 code never came back, so if you need to save money i would say a walker cat is a good choice in my opinion
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    I have a '99 Eldorado cat in my '97 Seville. The P# are different but that'a about all I can see as difference. Although the engines are identical between '97 and '99 for some reason the '99 Cat. P# is different than '98 and '97. 2000 however it does introduces the updated engine thus I don't know what to tell you.
    Dec 2012
    47
    il check for vacuum leaks & consider a walker cat perhaps & look further n to this issue 1200$ is alot of money thanks guys!!!!!
  8. Remove Advertisements
