Results 1 to 9 of 9
Thread: Several 2002 STS issues--just bought w/ only 24K miles
    TripleForte is offline Cadillac Owners Member
    Automobile(s): 2002 STS
    Jan 2013
    Costa Mesa, CA
    61
    4
    Hi guys, I'm a total Caddy newbie and appreciate all of the help and info available here at the Forum. I saw a teal-colored STS in 1995 and have wanted one for 17 years! Just bought a beautiful silver 2002 STS w/ only 24k miles from a fire captain's mother-in-law out here in Palos Verdes, CA, which seemed like a safe bet. I've spent hours researching the site (thanks AJ, Submariner, JimD and the rest of you), but am hoping for some confirmation and direction with some issues that have popped up since the purchase.
    1. The only issue at the time was the "Service Stability Sytem" warning on the dash. He had just put in a new battery and said the warning had only shown up AFTER he had put in the new battery. The warning only comes on once every time the car is started (never while driving) and I clear it with the INFO DOWN button. I don't know if there is some "relearn" required, but I'm getting current DTC's of C1284 and C1285 (Lateral Accelerometer Sensor Bias and Circuit Malfunctions). I have noticed that the brakes seem to rattle the whole car when doing a hard brake at high speed, so maybe I have a more serious ABS issue.
    2. The AM radio does not get any reception except for Los Angeles' powerhouse flamethrower AM640. All the rest is static. Will check for connection in rear window as suggested by others here. (Don't know if this might also be related to the new battery install.) There is an ONSTAR antenna attached to the rear window, but I'm not a subscriber and don't know if it's active.
    3. I'm getting a 3-4 second buzz/hum in the right-rear of the trunk on start-up and sometimes while driving. This could be an ELC issue related to the Stability System since it's intermittent, but I must confess that after having been accustomed to driving Chevy's and Fords down past "Empty" for most of my life, it's probably the fuel pump screaming at me to keep the tank above 1/4 full . What do you think?
    4. Lastly, the latest and biggest problem has been random stalling. It can happen in the driveway, stopped at a signal, turning, or driving on the freeway in a straight line. Sometimes the engine just dies quickly, and I can put it into neutral and restart it without any problem while coasting. Other times the tach will fluctuate wildly and sputter w/o dying so I will have to shut it off and restart. Usually, the engine starts right back up, but after a few times of having to do this the "Service Engine Soon" light came on and has stayed on. DTC's are P0385, P0386, and P1372 (Crankshaft Position Sensor B Circuit; Sensor B Performance; and Sensor A-B Correlation). P1372 has gone into "History," but P0386 goes in and out. All research here points to the CKP Sensors, so I have an appointment on Monday to have them changed w/ the AC Delco/Japan sensors suggested by many of you.
    Many thanks for any help/suggestions.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: Several 2002 STS issues--just bought w/ only 24K miles
    Welcome !!
    Looks like you're on top of the C codes and the CKP replacement.
    The brakes - do several aggressive stops from 70 - do NOT hold the brakes at the stop - drive away, get to 70 and do it again. After 3 stops, drive normally for 5 miles to cool the rotors. You might find the brakes a bit smoother.......the rotors don't warp; they pick up pad deposits from wimpy city driving and need to be cleaned once in a while.
    Enter the VIN (case sensitive) into www.compnine.com to find out what's built into that car. Save the page as a text document - you get only one readout per day on that site.
    The OnStar can be upgraded to analog if it has not been done. One way to tell is the rear window stub whip - the loading coil is in the top third of the whip on the old analog system; the new digital conversion whip has the loading coil in the bottom third. Cadillac dealer, couple hundred bucks to get it back online with some phone minutes, too.
    If you haven't done so, click my username, open the profile. Left column, lower part - 2 albums, 6 pages of 2002 STS parts and diagrams.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,702
    The 3-4 second humm is the ELC compressor going through test cycle. Be glad to hear it. It can run occassionaly depending on loading and where you drive.
    Sounds like you need rotors turned or pads.
    The radio reception can be tied to rear window tinting... do a search for it, either here or google. I remember not too long ago it was discussed on the forums.
  5. #4
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by TripleForte View Post
    Hi guys, I'm a total Caddy newbie and appreciate all of the help and info available here at the Forum....
    1. The only issue at the time was the "Service Stability Sytem" warning on the dash....I clear it with the INFO DOWN button. I don't know if there is some "relearn" required, but I'm getting current DTC's of C1284 and C1285 (Lateral Accelerometer Sensor Bias and Circuit Malfunctions).
    Since (someone) has been under the rear seat recently, it would be worth your time and effort to remove the rear seat cushion and thoroughly inspect the wire harness and component connectors on the LH side of the area. In particular the lateral accelerometer (item 7 in the picture).
    Don't pursue an ABS or brake issue until you have completed the lateral accelerometer wiring inspection. The accelerometers are part of the ABS system which is part of Stabiltrak. A fault in the lateral accelerometer circuit can/will send false data to the ABS Stabilitrak circuits and unpredictable braking action CAN result.
  6. #5
    Ranger is online now Cadillac Owners Member
    69
    82,283
    All I have to add is and nice find.
  7. #6
    The Gold's Avatar
    The Gold is offline Cadillac Owners Fanatic
    Automobile(s): 92 El Dorado
    Jul 2010
    San Francisco
    125
    Ditto, welcome !!
  8. #7
    Jan 2013
    Costa Mesa, CA
    61
    4
    Thanks guys. The CKPs have been replaced (total P&L $460) and the stalling issue (and codes) is resolved, as is the AM radio problem. Will have a look under the rear seat this weekend to c/o the harness and connections re: the accelerometer issue.
  9. #8
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    $460?! That's excessive.
  10. #9
    Feb 2006
    56,868
    GM pricing is about $96 each and 1.5 hours labor.
    .............so $460, at dealer rates, is about $100 high.
    RockAuto sells the CKP's for about $45 each and it's a driveway DIY in 2 hours.......... but everyone does not have the time, jacks, jackstands, or tools.
  • You may not post replies
