Coolant Type?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, Coolant Type? in Past Cadillac Vehicle Discussion; Quick question? What type of Coolant/Anti-Freeze does a 2000 Seville SLS take? I remember that the dealer put in the ...
    giantsfan is offline Cadillac Owners Member
    Automobile(s): 2001 DeVille
    Jan 2012
    72
    Coolant Type?
    Quick question? What type of Coolant/Anti-Freeze does a 2000 Seville SLS take? I remember that the dealer put in the type that should not have to be replaced for like 5 years. I'm getting a "Check coolant level" message on my dash and I'm concerned. As soon as the car cools down, I'll check the level.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Re: Coolant Type?
    Id have a flush done and have it filled with 50/50 Dex-Cool, pull the drain plug from the radiator and see what comes out, you can use the green stuff, just dont mix the two, hence my request to pull the plug. Both should be changed religiously every 3-4 years. 5 years is pushing it
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No need for a flush unless there's a blockage, or you're trying to flush out some stop leak product.
    You can use DEX, or the all makes/all models "green stuff" it makes no difference. Also, as long as the bottle of "green stuff" says it's mixable, you can mix them. The only downside is that you'll have odd colored coolant.
    Most would recommend a change interval of 2 years, 3 max, regardless of coolant type.
    Jan 2012
    72
    Re: Coolant Type?
    I had that done a few months ago by a mechanic who put the green stuff in. I then went back to the dealer for an oil change. They discovered that the green stuff was in the car and asked if I wanted it or the Coolant that lasted for 5 years. I opted for the 5 year Coolant. This was only about 7k miles and a few months ago. So, if it's not green, then it's orange? I was just planning to add some Coolant and I did not want to add the wrong stuff as this would be mixing two wrong things together. How many types of Coolant are there for this car?
    Sep 2010
    East Boston MA.
    29
    26,325
    5 years is a lot to ask of any coolant. DEX-COOL was designed to be a 5 year coolant, but several green coolants are advertised as the same. As posted, most here recommend a change every 2-3 years, regardless of type.
    Factory fill was DEX. As posted, you can use DEX or green stuff. As posted, they can be mixed as long as the bottle of green coolant states it can (pretty much any name brand).
    More importantly than coolant type, why are you adding it?
    Jan 2012
    72
    Re: Coolant Type?
    Oh, I'm nowhere near the 5 year point, the manager at the service dept. indicated that the coolant was 5 year coolant. I've never left any coolant in any car for 5 years. I guess this was his way of indicating to me that this was better coolant. I felt I needed to add some because the "check coolant level" indicator came on.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Just try topping it off and go from there, if it still does so start checking for leaks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,842
    Re: Coolant Type?
    "Top off" is a misleading term. The proper coolant level - COLD - is about halfway up in the reservoir. There is a "FULL COLD" legend on the top of the reservoir with a wide arrow that points down to about the tank mid-seam. Never check or adjust coolant level with the engine warm or hot.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Re: Coolant Type?
    Quote Originally Posted by Submariner409 View Post
    My resovoir is all black as midnight, i can't tell the level its at without looking down the neck even then i can't tell, i just fill it up until i see it creeping up before it hits the overflow tube..
    Feb 2006
    55,842
    Re: Coolant Type?
    Quote Originally Posted by vincentm View Post
    Bad practice. At least use a flashlight to look-see and wing it - 2 or 3 inches down is full enough. It's a wonder the system doesn't burp coolant out all the time.
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Re: Coolant Type?
    i stop about an inch or two before it hits the tube.. my resovoir is weird, not see through like others ive seen posted on here.
    Sep 2010
    East Boston MA.
    29
    26,325
    Yup. Some years/models use an all black tank.
    Jan 2012
    72
    Re: Coolant Type?
    Ok, but is it the green or the orange type of coolant that I should be using? I don't think I should be mixing the two, should I?
  16. #14
    Sep 2010
    East Boston MA.
    29
    26,325
    From post #3:
    Quote Originally Posted by MoistCabbage
    From post #5:
    Factory fill was DEX. As posted, you can use DEX or green stuff. As posted, they can be mixed as long as the bottle of green coolant states it can be (pretty much any name brand).
    Don't just fill it and forget about it. You need to find the source of your leak.
  17. #15
    68
    81,887
    Re: Coolant Type?
    It's a sealed system. You should never have to add coolant. If you do, you have a leak. You need to find and fix the leak.
  18. Remove Advertisements
