Codes... - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Cadillac Seville / Cadillac Eldorado Forum Discussion, Codes... in Past Cadillac Vehicle Discussion; There are plenty of blank gold keys on e-bay, the price starts from $19+$10 S&H (for me in Canada, for ...
  1. #16
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Codes...
    There are plenty of blank gold keys on e-bay, the price starts from $19+$10 S&H (for me in Canada, for you in US may be way less) for the full VAT range. For $39 you get a pair (ignition + doors). Just search for "Cadillac gold key".
  2. #17
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Re: Codes...
    Still getting this issue, just ordered a new ignition cylinder. Gonna hunt down a new gold key on ebay too.
    codes i just pulled are:
    B2710 Pass-KeyII open/shorted key pellet
    B2780 Pass-KeyII Wrong resistor value before good
    B2781 Theft Deterrent system enabled
  3. #18
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,871
    Re: Codes...
    Ok, so got the new ignition cylinder a few weeks ago and haven't had time to doing the replacement which i'm hoping to do so Friday. Alldata is useless doesn't show crap on it, only labor times for steering column lock. So here i am asking you fine folks.
    How the hell do i do this? lol
  4. #19
    luckyenoughnc is offline Cadillac Owners Member
    Automobile(s): 1996 Eldorado, '04 Deville DTS, '05 Cts
    Feb 2012
    60
    4
    Re: Codes...
    My wife's 96 Eldo is getting the security message, when using the spare key it is the same. Suppose that means it is the cylinder. I see mention of a vats bypass, what is that process? Thanks!
  5. #20
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,593
    Do a search for bypass vats. Read carefully as if you cut the wrong wire bad things happen. Basically you find the resistance of your key pellet and solder resistors together to same and put these in the wiring loop to lock, cut tap in at the base of steering column.
  6. #21
    Feb 2012
    60
    4
    Re: Codes...
    Thanks!!
  7. #22
    68
    81,755
    Re: Codes...
    DO NOT get suckered into buying any of the "kits" you'll run across when you do the search. You'll just end up paying $60 for a $2 resistor that you can get from Radio Shack.
  8. Remove Advertisements
